LeGiT_Flat4 Posted December 12, 2015 Share Posted December 12, 2015 So I had been seeing the typical drop of oil collecting at the bottom of my oil filter that usually means the oil cooler gasket needs to be replaced so I decided to finally get that done. Pretty simple job right? Drain oil. Drain coolant. Remove oil cooler. Swap gasket. Reinstall. Fill oil. Fill coolant. Then I started up the car to go through the burping process. Meanwhile, under the car...I found that oil was leaking like a faucet:spin: I couldn't understand how that was even possible . So I drained the oil and coolant again to see wtf. I loosen the oil cooler center bolt half a turn and I see part of the gasket fall out. Well...that's not good. Got the oil cooler out again but I just can't figure out how this happened. Only thing I can think of is over-torquing but the center bolt came loose with very little effort so it certainly didn't feel like I torqued it too much. Still doesn't make sense how a chunk of the gasket could get ripped away. Taking a closer look at the new gasket, it has a different look and feel than the original and seems like it's even thinner. It has smooth edges whereas the original has fairly square edges and the original just seems less flimsy/more sturdy. I got if from the dealership and seems to be the right part number. Has anyone else had this kind of trouble with a new gasket? Did I get a defective one? Or did I just do something wrong? Link to comment Share on other sites More sharing options...
jmr302 Posted December 12, 2015 Share Posted December 12, 2015 I wonder if you didn't just pinch an edge of it. I just changed mine a couple weeks ago and had to check that the gasket hadn't popped out of the groove several times. PS: I just unbolt the tube from the front of the crankcase so the coolant hoses are more free to move. No need to drain the cooling system then. Link to comment Share on other sites More sharing options...
quick4dr Posted December 12, 2015 Share Posted December 12, 2015 it could have had a small tear in it out of the package. Not uncommon when a parts guy cuts open boxes, or seperates attached bags that his razor nicked the gasket. Link to comment Share on other sites More sharing options...
LeGiT_Flat4 Posted December 13, 2015 Author Share Posted December 13, 2015 Thanks for your responses. As much as I'd like to believe it was the parts guy's fault, I inspected the package and couldn't see any sign of a slit or cut from a blade that would have nicked the gasket. I guess the pinch theory is probably the most likely explanation, even though it still seems weird the gasket would just split in 2 places like that. I picked up a new gasket today and reinstalled the oil cooler. Filter seems dry as a bone now....so far anyway. I'll be keeping an eye on it. Link to comment Share on other sites More sharing options...
