hdcolo Posted December 11, 2015 Share Posted December 11, 2015 . . Hello, , Having done many many engine swaps on the earlier generations I have learned that the recyclers compatibility books for the EJ25 lack alot. . For instance, , The number of bellhousing bolts does not mean one year won't fit another. . And later years and earlier ones still work but the cam pully or crank gear need to be swapped. . Or that you can drill and tap the head on ealier engines to use on EGR models. . . . So here is my question. . I recently purchased an '08 Outback that needs an engine. . People are telling me that the Forester EJ25 won't work in the Outback but no one seems to know what the differences are. . . . Any ideas? ? Link to comment Share on other sites More sharing options...
Max Capacity Posted December 15, 2015 Share Posted December 15, 2015 PM m sprank he would know. GT's and XT's can use a ej257 short block and bolt your heads on it using the gasket set for your year car. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
