PATS4LIFE Posted December 17, 2016 Share Posted December 17, 2016 I just finished install my hella supertone without using the harness and it works fine,my question is I tap in my trigger wire on the passenger side instead of driver side...both of my stock horns are also hook up still..my question now is does it make any difference tapping trigger wire to either passenger/driver side??thanks Link to comment Share on other sites More sharing options...
Grnlantern1 Posted December 17, 2016 Share Posted December 17, 2016 I just finished install my hella supertone without using the harness and it works fine,my question is I tap in my trigger wire on the passenger side instead of driver side...both of my stock horns are also hook up still..my question now is does it make any difference tapping trigger wire to either passenger/driver side??thanks Not Really but Each Side has its own Fuse so you want to make sure you change it to a 15amp.. The Stock Fuse is 7.5amp.. If you lay on the Horns it will Blow the Fuse because they Draw around 11amps..[emoji15] Sent from my SM-G930P using Tapatalk Link to comment Share on other sites More sharing options...
PATS4LIFE Posted December 17, 2016 Share Posted December 17, 2016 Not Really but Each Side has its own Fuse so you want to make sure you change it to a 15amp.. The Stock Fuse is 7.5amp.. If you lay on the Horns it will Blow the Fuse because they Draw around 11amps..[emoji15] Sent from my SM-G930P using Tapatalki forgot to mention I did use a relay for the hella horns,do I still need to change the fuse? Link to comment Share on other sites More sharing options...
Mizman73 Posted January 19, 2017 Share Posted January 19, 2017 when putting the hella horns in do you keep the OEM ones connected as well? Link to comment Share on other sites More sharing options...
PATS4LIFE Posted January 20, 2017 Share Posted January 20, 2017 when putting the hella horns in do you keep the OEM ones connected as well?yes as long as your using relay for the hella horn Link to comment Share on other sites More sharing options...
Mizman73 Posted January 21, 2017 Share Posted January 21, 2017 Thanks Pats4Life Big Game Sunday Go Pats If I keep the oem horns and add the hellas , use the relay for the hellas, will i need to upgrade the fuse from 7 to 15? Link to comment Share on other sites More sharing options...
PATS4LIFE Posted January 21, 2017 Share Posted January 21, 2017 Thanks Pats4Life Big Game Sunday Go Pats If I keep the oem horns and add the hellas , use the relay for the hellas, will i need to upgrade the fuse from 7 to 15?no you don't have to change the fuse.. I'm actually going to add another pair of hella horn that I just received today, I will replace the both oem horns using relay also.. Yup excited for Sunday game and nervous:) Link to comment Share on other sites More sharing options...
bfkellogg Posted January 22, 2017 Share Posted January 22, 2017 I used the subi mods standard bracket and turned it into a quad Sent from my SM-N920V using Tapatalk Link to comment Share on other sites More sharing options...
hoppyjr Posted January 22, 2017 Share Posted January 22, 2017 I used the subi mods standard bracket and turned it into a quad Sent from my SM-N920V using Tapatalk You're apparently a horny person. Link to comment Share on other sites More sharing options...
PATS4LIFE Posted January 31, 2017 Share Posted January 31, 2017 I used the subi mods standard bracket and turned it into a quad Sent from my SM-N920V using Tapatalk Did you use separate relays?or you just used one relay for all 4?thanks Link to comment Share on other sites More sharing options...
bfkellogg Posted January 31, 2017 Share Posted January 31, 2017 Did you use separate relays?or you just used one relay for all 4?thanks I used the subispeed harness kit one relay for all 4. To tell you guys the truth i accidentally ordered the harness for the quad kit instead of the standard one. So i scrambled and got 2 more horn real quick and made the rest work. Link to comment Share on other sites More sharing options...
PATS4LIFE Posted January 31, 2017 Share Posted January 31, 2017 I used the subispeed harness kit one relay for all 4. To tell you guys the truth i accidentally ordered the harness for the quad kit instead of the standard one. So i scrambled and got 2 more horn real quick and made the rest work. Ok cool thank you gonna another pair:) Link to comment Share on other sites More sharing options...
