Alexander- Posted December 8, 2015 Share Posted December 8, 2015 Hello, The shifter on my 06 Legacy Wagon has a sloppy feel to it, so it has to be fixed. I have found a shifter bushing kit by Prothane part number 16-1602. Some websites claims it fits the 06 Legacy, others claim it doesn't. Has anyone ever tried it on their Gen 4 Legacy? Does it improve gear shifting? Does it remove any play while in gear? Here is a link to it on eBay: http://www.ebay.ca/itm/16-1602-Prothane-Poly-5-Speed-Manual-Trans-Shifter-Bushing-Kit-Fits-Subaru-/191249963062 Thanks! Link to comment Share on other sites More sharing options...
Max Capacity Posted December 8, 2015 Share Posted December 8, 2015 We tend to recommend you only buy from the vendors or trusted members on this site. I buy most of my stuff like that from "Underdog" you can PM him, or call http://www.AZPinstalls.com Get the right part the first time. You can tell them I sent you to them. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ashwinearl Posted December 8, 2015 Share Posted December 8, 2015 One of the first things I did was put in a Kart Boy shifter bushing set and then almost immediately went with their short throw shifter in combination with it. I think the Legacy 5speed has such long throws to begin with that a short throw helps. Even with the short throw shifter, the throw from 4th to 5th is still a long one. regardless, just the right bushings will help a lot with the slop in the shifter some of which is part of the stock design and some might be from age. Link to comment Share on other sites More sharing options...
