Dgould7 Posted December 5, 2015 Share Posted December 5, 2015 Doing the hub bearing replacement this weekend. My axle is definitely seized into the hub bearing. It's not going out and back like it should. Used sledge heat everything...Im just gonna say F it and do the whole axle anyways. Because I don't have access to scrap or anything to build a custom axle pusher thing. Does anyone know if that axle will just slide through the hub like the rear (saw in YouTube video)seized together and all? It doesn't look real promising and that the only option is to push that axle back out of the hub bearing no matter what. The hole on the hub looks to small to pull it through. But that thing is not going back I've smack and sprayed and smacked and sprayed. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 5, 2015 Share Posted December 5, 2015 worst case is you have to remove the spindle from the bottom of the strut and take it to a shop. You'll need to get the front end aligned after you put it back together. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Dgould7 Posted December 5, 2015 Author Share Posted December 5, 2015 Woooo. Got that thing off. Went to Sears, bought a Craftsman 7 ton two jaw gear puller. Jack stand for leverage to keep the hub from spinning. Kept cranking and cranking with some heat on that axle and she finally broke loose. Thank God!!! Now to clean the rust up and slap the new one on. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 6, 2015 Share Posted December 6, 2015 I hope you put anti-seize compound on all the threads and some axle grease on the splines where they go into the hub. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Dgould7 Posted December 6, 2015 Author Share Posted December 6, 2015 Nope. Put all back together nice and dry for the next guy. Just playing man. I'm putting it back together tomorrow morning. Got a tube of antiseize and some grease ready to go. That was the first thing I learned looong ago. Really helped with the removal of bake hardware this time around since I've done all 4 pretty recently. Link to comment Share on other sites More sharing options...
