sleepercell Posted December 2, 2015 Share Posted December 2, 2015 I just bought a 07 Lgt. Beautiful car love it but she is starting to cost as much as a gf.. The problem is the car Sat thru a n.e winter no major rust but almost all bushings dried out among other parts. I just purchased New rotors w pads n b.lines. tires. New belts water pump w hoses. Front bushings n links oes. Knock sensor. An now only run 93. Its my baby. Thought I was good order rsb w hd links. Then go-to get inspection. They tell me rear lat. Link bushings need replace. Shld I keep buying top line parts an replace as breaks or get a bushings kit and replace jus bushings.? Top line of course. Thanx u for any advice on subject Link to comment Share on other sites More sharing options...
sleepercell Posted December 2, 2015 Author Share Posted December 2, 2015 The racing side of me wants all after market parts replaced but it cost so much it's scary if u buy things u don't need at time What would u do buy stock r lat links or jus replace bushings car Sat for yr. Its at turbo Link to comment Share on other sites More sharing options...
Merc6 Posted December 2, 2015 Share Posted December 2, 2015 I just bought a 07 Lgt. Beautiful car love it but she is starting to cost as much as a gf.. Welcome to the 4th gen section of the LegacyGT.com forums An now only run 93. So what were you running before, 91? The problem is the car Sat thru a n.e winter no major rust but almost all bushings dried out among other parts. I just purchased New rotors w pads n b.lines. tires. New belts water pump w hoses. Front bushings n links oes. Knock sensor. Its my baby. Thought I was good order rsb w hd links. Then go-to get inspection. They tell me rear lat. Link bushings need replace. Shld I keep buying top line parts an replace as breaks or get a bushings kit and replace jus bushings.? Top line of course. Thanx u for any advice on subject I know that feel, my whole front suspension is toast from Cleveland winters. The question to ask is oem good enough and how long does it last vs the "Legit" aftermarket replacements. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
Max Capacity Posted December 2, 2015 Share Posted December 2, 2015 Belts and hoses, as in timing belt kit ? you need to replace that at 105,000 miles. Slow down, Why did you buy a knock sensor ? Moog end links are like $60.00 I buy most of my parts from "Underdog" you can PM him. He's in Ayer MA. Or http://www.AZPinstalls.com, they are in NJ. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
