PrelateBishop Posted October 28, 2015 Share Posted October 28, 2015 Is there any reason a set of wheels off of an '06 Spec B would not fit a bone stock '09 OBXT? I think the '06 Spec B wheels are 18x7 with a +55mm offset; 5x100 bolt pattern. I think the '09 OBXT wheels are 17x7 with a +48mm offset; 5x100 bolt pattern. If this is true, I believe the end result would be for the wheels to "move" inward 7mm (approx. 1/4"). If this is all correct, any issues you foresee? If not correct, what did I miss? Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted October 28, 2015 Moderators Share Posted October 28, 2015 They should fit fine. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
