Adam7284 Posted October 22, 2015 Share Posted October 22, 2015 Over the past weekend I took a trip in my 05 LGT (completely stock) with about 109k miles on it. Anyways, I started hearing almost a rattling noise from the front of the car. It seemed to go away when warmed up. I attached below a sound clip of it. https://youtu.be/uHEYftKueqg Link to comment Share on other sites More sharing options...
Max Capacity Posted October 22, 2015 Share Posted October 22, 2015 I'd pull the timing belt cover and check the idler pulleys first. wasn't the timing belt and kit just replaced ? it's do at 105,000 miles. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted October 22, 2015 Share Posted October 22, 2015 I'd pull the timing belt cover and check the idler pulleys first. wasn't the timing belt and kit just replaced ? it's do at 105,000 miles. +1 on that....do it asap because if that fails, you are looking at significant repair costs. I would also replace all of the idler pulleys and water pump as you are due for a t-belt Link to comment Share on other sites More sharing options...
starionesir Posted October 22, 2015 Share Posted October 22, 2015 Did you check the pulleys on the accessory drive? I've seen some idlers make some crazy noises but usually don't go away once warm. Link to comment Share on other sites More sharing options...
Adam7284 Posted October 22, 2015 Author Share Posted October 22, 2015 Yeah, I'll check it out. But I had the timing belt and water pump replaced with a Gates Kit as soon as I hit 100k though. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted October 23, 2015 Share Posted October 23, 2015 ^ gates are not that good IMHO, my car had one on it and it had a recommended change mileage of 62K whaaaaaaa? Subaru is 105K Link to comment Share on other sites More sharing options...
INTP_ty Posted October 23, 2015 Share Posted October 23, 2015 If it is piston slap, don't listen to the Internet experts when they say you need to drop 3k on a rebuild. They had me all worried after my rebuild. 125k miles later, compression is fine. Just a thought Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted October 23, 2015 Share Posted October 23, 2015 I would not rebuild due to piston slap, however I did have to have a reseal done and I had them correct the issue at the same time Link to comment Share on other sites More sharing options...
