LittleBlueGT Posted September 26, 2005 Share Posted September 26, 2005 This is driving me nuts. I still have trouble shooting to do. Any ideas as to why I only get it in one speaker? Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
executor485 Posted September 27, 2005 Share Posted September 27, 2005 I cant say for sure why it would be just one speaker, but when I started to get alternator noise in my Dodge Caravan, the alternator was about to die. Once I replaced the alternator, life was good. If you have recently taken out the stereo or something, you might want to check your ground wires again. Normally getting alternator noise through the speakers is a sign of a bad ground connection. I am no expert at this, but these are just a few things that I had to deal with when I installed my stereo in my van... If I pass you on the right, I'm flipping you off. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted September 27, 2005 Author Share Posted September 27, 2005 Thanks, I hope the alternator is in good shape, the car is only 2 onths old! I have checked all of my grounds, all 4 gauge or bigger and all are making excellent contact. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
mwiener2 Posted September 27, 2005 Share Posted September 27, 2005 what's the setup? new speakers? amp? HU? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
PGT Posted September 27, 2005 Share Posted September 27, 2005 swap the leads at the amp - does the noise follow or stay with the speaker? Honestly? Sounds like an amp issue to me. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted September 27, 2005 Author Share Posted September 27, 2005 swap the leads at the amp - does the noise follow or stay with the speaker? Honestly? Sounds like an amp issue to me. Next time I work on the car that is what I am doing, I also have a feeling it is an amp issue. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
PGT Posted September 27, 2005 Share Posted September 27, 2005 also, swap the leads to the CleanSweep as a further check. Could be there as well. Doublecheck all your speaker grounds too....make sure they are clean and not touching anything. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted September 28, 2005 Author Share Posted September 28, 2005 also, swap the leads to the CleanSweep as a further check. Could be there as well. Doublecheck all your speaker grounds too....make sure they are clean and not touching anything. I am going to be checking my speaker ground soon. I don't think it is coming from the CS because I can disconnect my RCA's and the noise is still there. It is extremely annoying! I use to compete in car audio about 11 years ago, never ever had a problem in a car I had done the install in, now this!!!! Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
Boulderguy Posted September 28, 2005 Share Posted September 28, 2005 Oh hell, if this is your first real problem I'd say you're looong overdue...welcome to the club. I'm wondering if one of your RCA's got nicked & is grounding somewhere 'tween source & amp. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted September 28, 2005 Author Share Posted September 28, 2005 Oh hell, if this is your first real problem I'd say you're looong overdue...welcome to the club. I'm wondering if one of your RCA's got nicked & is grounding somewhere 'tween source & amp. I can disconnect the RCAs and still get the noise. It is either the speaker, the speaker wire or the amp. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
Boulderguy Posted September 28, 2005 Share Posted September 28, 2005 I've never heard of alt noise being introduced at speaker levels (which doesn't mean it can't happen), so I suspect it's the amp, but only one channel? Tried switching the speaker leads to see if the noise moves? Is it possible that you're only hearing it from one side b/c of speaker proximity? Link to comment Share on other sites More sharing options...
LittleBlueGT Posted September 28, 2005 Author Share Posted September 28, 2005 Only one speaker, I am sure. haven't had a chance yet to change the speaker wire to see if it moves. If it is the amp I have no idea how to fix it. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
Boulderguy Posted September 28, 2005 Share Posted September 28, 2005 If it is the amp I have no idea how to fix it. There's a special tool for that, called the BFH... Link to comment Share on other sites More sharing options...
PGT Posted September 28, 2005 Share Posted September 28, 2005 as long as you don't need to have the smoke put back in the amp, it's repairable. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted September 28, 2005 Author Share Posted September 28, 2005 BFH... What is that? Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
PGT Posted September 28, 2005 Share Posted September 28, 2005 Big F'ing Hammer Link to comment Share on other sites More sharing options...
LittleBlueGT Posted September 29, 2005 Author Share Posted September 29, 2005 BFH, I am not that frustrated yet! Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
Boulderguy Posted September 29, 2005 Share Posted September 29, 2005 just a matter of time... Link to comment Share on other sites More sharing options...
