Akasa Posted October 6, 2015 Share Posted October 6, 2015 My car (2005 5MT GT) seems to have developed this odd rattle in the shifter area, which I can't for the life of me diagnose. I hear the rattle very loudly when taking a sharp corner in 3rd gear, generally around 4000-5000 RPM, or at around 5000 RPM in 3rd gear. Oddly enough, I also hear this same rattle sound when I bring the car up to about 4000-5000 RPM with the car in neutral, which is why i'm hesitant to diagnose it as a bad differential. I'm honestly at a loss here. I can upload a video if that will be helpful. Thanks guys! Link to comment Share on other sites More sharing options...
I3eXa Posted October 6, 2015 Share Posted October 6, 2015 a video will always help but silly question. Have you taken the console boot off and made sure it it's a coin or something down in there rattling by chance?!?! Link to comment Share on other sites More sharing options...
Akasa Posted October 7, 2015 Author Share Posted October 7, 2015 a video will always help but silly question. Have you taken the console boot off and made sure it it's a coin or something down in there rattling by chance?!?! I'll post a video up when I can have my friend record it. I've taken the entire center console apart, made sure the snap rings were tight on the linkage assembly, made sure that the shift fork was tight to the short throw shifter, i've checked all of that. I'll see if maybe it's the heat shield rattling that encompasses the drive shaft and linkage. Link to comment Share on other sites More sharing options...
FJuan Posted October 7, 2015 Share Posted October 7, 2015 Sub for video. It could be several things and need to hear what it sounds like first. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
I3eXa Posted October 7, 2015 Share Posted October 7, 2015 Yep. Could be that heat shield. Also, does the shifter itself rattle like can you grab it and make the noise stop or is it coming from below? Sent from somewhere in Potatoland Link to comment Share on other sites More sharing options...
Hannya Posted October 8, 2015 Share Posted October 8, 2015 Try this: Tighten your shift knob. I had an annoying rattle a year ago that I actually took my car back to my tuner. I took one of the techs out for a drive and we both scratched our heads. Rolled the windows up and the sound became more audible. He looked down at my shifter and told me to stop the car. With a blank stare. He twisted my shift knob and we took the car back on the road. He always give me Shit since then. Link to comment Share on other sites More sharing options...
jonah_ow Posted October 10, 2015 Share Posted October 10, 2015 I had what I believe is your same problem. It eventually just went away, and I believe it was from the shift knob either not seating on the threads, or just not being tight enough. Trying to remember. Link to comment Share on other sites More sharing options...
Akasa Posted January 7, 2016 Author Share Posted January 7, 2016 Alright guys, so I apologize for the late response. I have gone under the car, checked for rattling heat shields, checked to see if the linkage is rubbing anywhere, i've torn the center console out, checked all of the bolts, tightened the connection where the fork meets the shifter. I literally cannot figure this out. I even removed the bracket that held the downpipe to the transmission, since it had broken when I did my up-pipe install. I've included 2 videos here, first is the car decelerating in 2nd gear, the rattle tends to happen around 3500-4000 RPM REGARDLESS of which gear i'm in, which is what makes me wonder if it's just something making contact with something else; sound tone changes when I move the gear selector in gear. https://www.youtube.com/watch?v=95XSqZVimXQ The next video is a quick shot of the car at a stop light in 4th gear with the clutch depressed; the rattle is still present when revving the engine with the clutch depressed. Again, I have tightened everything I can think of; I really don't know where to begin here. https://www.youtube.com/watch?v=xj4LnKEhakI Link to comment Share on other sites More sharing options...
