2015 Subaru Legacy 2.5i HID Retrofit
The headlight is 31" long so no way it'll fit into any both of my ovens.
OEM Black Butyl will need to be bake at 225c for minutes.
Best to use a card box with heat gun.
- Denso Slim Potted
- Osram CBI 5500k
- XB35 5500k
- TRS HD Relay Harness
- RX350 AFS +STI-R
What projectors would fit? going easiest to hardest
RX350 non-afs, EVOX-R/E55, Bosch E46, RX-350 AFS, G37, Maxima, MD2S 3".
Starting off
16288662576_95282eaf4f_b.jpg15 Legacy 2.5i Retrofit by [/url], on Flickr
RX350 AFS, RX330 AFS, MH1, MD2S
16127051718_0906cd2b20_b.jpg15 Legacy 2.5i Retrofit by , on Flickr
15692175534_173b47775a_b.jpg15 Legacy 2.5i Retrofit by , on Flickr
Edited by im2c0ol
16' Legacy Mods: 55w HID + XB35 5500k, LEDS upgrades, XB Type T Fog, 20mm SB.
Custom Footwell Illiminate Kit; http://legacygt.com/forums/showthread.php/15-legacy-outback-footwell-illumination-kit-237567.html
puke... :(
OP:
I put my headlights about 15ft away but directly in front of my 155kBTU Salamander for about 5-8min and then rotated them and then again for another 5-8min.
I was able to work on them while they stayed heated. I kept a sweatshirt and gloves on so to not burn my arms or hands. This has worked very well for me over the years. yes i was sweating my arse off but it's brief.
Hope that helps others. ;)
hahaha. yeah right. I can grab pretty much anything that is too hot for others but it's the backside of my hands that the heat hits. That is a sensitive area for all of us.
I can grab the headlights, that doesn't burn me, but the butyl can because it sticks to you like glue and traps in the heat.
I wear nitrile gloves and then rubber palmed gardening gloves over top of them. Keeps good insulation.
Simply with a card board box and a $21 bucks Wagner 0503008 HT1000 1,200-watt Heat Gun and 15 minutes later.
16128735217_f35cfeea15_c.jpg15 Legacy 2.5i Retrofit by [/url], on Flickr
16128418049_bd14db6479_c.jpg15 Legacy 2.5i Retrofit by , on Flickr
16128414759_b2f696f08b_c.jpg15 Legacy 2.5i Retrofit by , on Flickr
15692166034_b3a422a120_c.jpg15 Legacy 2.5i Retrofit by , on Flickr
the two un-swap-able Koito LED C-Led
16313728752_5a0a5e22a6_c.jpg15 Legacy 2.5i Retrofit by [/url], on Flickr
stock halogen are identical size, front end lens are identical. RX350 non afs low beam only will fit in without much mods.
16313723902_5c4cb115ce_c.jpg15 Legacy 2.5i Retrofit by , on Flickr
Dremel the bottom part make room for solenoid
16312794161_85e495e59d_c.jpg15 Legacy 2.5i Retrofit by , on Flickr
16127034848_543312f78b_c.jpg15 Legacy 2.5i Retrofit by , on Flickr
16128721637_2bab3d4a27_c.jpg15 Legacy 2.5i Retrofit by , on Flickr
test fit RX350 AFS front end
15692158404_549023b0f1_c.jpg15 Legacy 2.5i Retrofit by , on Flickr
Blue Shield Color mod + STI-R Clear Lens.
16313714152_014773f7c6_c.jpg15 Legacy 2.5i Retrofit by , on Flickr
wall shot of left retro vs right with pnp hid
16127179130_e37c395853_c.jpg15 Legacy 2.5i Retrofit by [/url], on Flickr
stock on left vs retro with color mod on right.
16297352386_ab9ecff79d_c.jpgRetro by , on Flickr
making the wiring for bixenon when I turn high beam, basically I get dual high beam. ;)
16151728579_03b6d7b2d8_c.jpgRetrofit by , on Flickr
16337907505_c6257bca7c_c.jpgRetrofit by , on Flickr
how I paint the shield
16334590396_541b6f8a59_c.jpgRetrofit by , on Flickr
shield modding for mounting and sharpness tuning
15738102884_a0e94273f0_c.jpgRetrofit by , on Flickr
dremel the housing
16358803501_d157b4899a_c.jpgRetrofit by , on Flickr
16173175080_7c18df37d3_c.jpgRetrofit by , on Flickr
mounting the projector
15740579373_79d0d9fe69_c.jpgRetrofit by , on Flickr
2nd projector prep ready to go
16359647972_be2ff4f0c1_c.jpgRetrofit by , on Flickr
I would look into obtaining 2015+ WRX Limited headlights for the projectors. They are LED low beam projectors and are self leveling as well. Might be worthy of dissection although they are rather small projectors. 2" maybe??
I can get you pics when I pick up my car late next week.
  • 1 year later...
the wrx limited led's are junk compared to a hid retrofit. i also dont think they can be retrofitted easily.
FWIW The Retrofit Source recommends 35 watt ballasts (not 55 watt) for HID low beams, and it is plenty of light. 55 watt will overdrive the bulbs, shortening their life, and probably not produce that much additional usable light (HID uses high voltage to produce the arc -- warm up takes a few seconds at least, then the voltage drops because it takes less voltage to maintain the arc -- less voltage but more light than a similar sized halogen bulb, for example).
I did a similar retrofit on a WRX replacing halogen projectors with Morimoto D2S, it is really more of a process to open the headlights (drop bumper, remove headlights, open headlights, etc) than to swap out a projector, especially if you can find a mounting bracket (less dremel work and customized fitting involved).
Also, there are a lot of expensive HID bulbs on the market, I have been really happy with my relatively cheap Morimoto bulbs.
And the bi-xenon function is the best, when they open up with your highbeams it is daylight time at night.
Edited by upstater
These bad boys came in:wub:
RX350 non-afs, ordered from lightwerkz.net. If you sign up for their email list you get a discount which made them the cheapest place I could find at $170. Also purchased Morimoto D2S 4300k bulbs and high beam splitters from them as they were cheaper than I could've made them for.
Also picked up some AMP to D2S adapters so I can use my current XenonDepot ballasts until my kit sells and I can order some Morimoto ones. Had to do this to keep from exceeding my mod budget:p
http://imgur.com/BFb6SL6.jpg
What bulbs are u using for your high beams?
My legacy has OEM HID low beams (using Morimoto 5500K bulbs) and OEM high beams (halogen bulbs).
When I did the WRX I had the same thing, but used a Morimoto D2S projector with bi-xenon, 35 watt ballasts, and same bulbs (replacing the WRX OEM halogen low beam projector), along with OEM high beams (halogen).
If you have a bi-xenon projector, you won't need anything extra for high beams, imho, because your HID projector will open up and the OEM high beams will also come on at the same time.
Tested out my projectors today in preparation for my retrofit tomorrow. Repeatedly triggered the solenoids using a 9v battery to make sure they didn't stick at all, and got the bulbs powered up to make sure they and the amp to D2S adapters I purchased work. Really looking forward to it:cool:
