Explanation
Quick search found this....
Unofficial Legacy GT “Stage Upgrade” Definitions
Stage 0: Stock with or without; panel filter / intake, or pulley
Stage 1: Stage 0 plus an upgraded ECU map/tune
Stage 1.5: Stage 0 plus a down pipe, and basic stage 2 map/tune
Stage 2: Up pipe, down pipe, upgraded stage 2 ECU map/tune. With or without Stage 0
Stage 2.5: Stage 2 plus a header, cat back exhaust, intercooler upgrade, further upgraded ECU map/tune
Stage 3: Stage 2.5 plus upgraded turbo, and stock fuel system
Stage 3.5: Stage 2.5 plus upgraded turbo and upgraded fuel system
Stage 4: Stage 3 or 3.5 plus upgraded heads or a full engine build
Stage 4.5: Stage 3 or 3.5 with both upgraded heads and a full engine build
Stage 5: Let’s dare to dream!!! Maybe fully built H6 Twin Turbo???
*Having an upgraded wastegate actuator, boost control solenoid, or TGV deletes are just pluses and do not fit into any one “stage” category.
**If you are running a methanol injection system you simply add a “+” to your Stage. I.E. Stage 2.5 +
Is it possible for me to upgrade my navigational screen to possibly equal the later Spec-B's that being displaying more than the rudimentary MPG,and other such into a package that might indicate true engine performance.....is it a matter of replacing a chip or am I thinking of the impossible.i bring this up because of a later legacy display that gave truly useful intelligence .
