Soarer Posted September 22, 2015 Share Posted September 22, 2015 Can you flash a map onto an ECU using an AccessPort and then pull that map off the ECU using ECU Flash or ROM Raider? I'm wondering if I can use one of the Cobb base maps as a starting point and then use open source to pull the map off the ECU, edit it and then reinstall it. Link to comment Share on other sites More sharing options...
covertrussian Posted September 22, 2015 Share Posted September 22, 2015 Nope, Cobb locks the ECU. Only time you can unlock it is when you remove the Cobb's maps. This is done to protect their intellectual property. But I wouldn't sweat over it, since Cobb's maps are off the shelf generic, your better off getting a custom eTune. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
