southbay88 Posted September 10, 2015 Share Posted September 10, 2015 So I leave work today and my fuel tank is extremely low. Now I have been trying to fill up and there is no gas getting in the tank whatsoever. I have tried 3 different gas stations. I am wondering if anyone else has had this problem. My biggest issue is I can't locate or find a diagram of where my EVAP canister would be. Any suggestions??? Link to comment Share on other sites More sharing options...
apexi Posted September 10, 2015 Share Posted September 10, 2015 Here's a picture of where the canister is located. I also came across the link below where an impreza owner had a similar problem, and it ended up being some sort of fuel tank pressure valve. http://forums.nasioc.com/forums/showthread.php?t=2180454 Link to comment Share on other sites More sharing options...
shortfusemonkey Posted September 10, 2015 Share Posted September 10, 2015 i had an impreza that did this, I ended up having to put a new filler neck on it. Link to comment Share on other sites More sharing options...
JmP6889928 Posted September 11, 2015 Share Posted September 11, 2015 Anxious to hear. I've had this problem for 3+ years. I changed EVAP canister to one off a 5K wreck with no luck. I then changed shut valve and still no luck. Really would like to know where to look next. Link to comment Share on other sites More sharing options...
southbay88 Posted September 13, 2015 Author Share Posted September 13, 2015 So strange. I let the car sit for a day and was going to take it to a mechanic to fix it but tried to fill it up one more time. It worked just fine! This same thing happened to me a couple months ago. I don't know what to think, but am happy that its working fine now. I appreciate all the replies and will bump this thread if it comes up again. Link to comment Share on other sites More sharing options...
