whitrzac Posted September 5, 2015 Share Posted September 5, 2015 I picked up a spare longblock to build for my LGT. Engine had a rod knock, I paid ~$300 for a complete longblock... Disassembled it. Heads/cams look good with no scoring. Crankshaft is fubar. #4 rod bearing is now part of the crankshaft. I don't need this rebuilt now, I don't need this this month. I'm not installing it until it gets warm out next year. Options as I see them: 1: new oem shortblock, forged pistons. Simple, probably not cheap... 2: new crank, new bearings, forged pistons 3: machine crank, etc Does anyone have experience on what is the least expensive route? Link to comment Share on other sites More sharing options...
Pazuzu Posted September 5, 2015 Share Posted September 5, 2015 I'm considering going with turn in concepts "not quite badger short block" it's oem sb with je pistons. 2875 free shipping ground in u.s. . http://turninconcepts.com/subaru_engines/ Sent from my 831C using Tapatalk Link to comment Share on other sites More sharing options...
whitrzac Posted September 6, 2015 Author Share Posted September 6, 2015 Does anyone make a forged piston with a <8.2cr? It's going to be run on 91 piss water, it needs all the det resistance I can get. Link to comment Share on other sites More sharing options...
Pazuzu Posted September 6, 2015 Share Posted September 6, 2015 http://www.rallispec.com/eng_sbl_rssb25v.html Sent from my 831C using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted September 6, 2015 Share Posted September 6, 2015 Where do you live ? Any decent machine shop can advise you what to do. If you get a new cranks the block will need to be line bored. What are your HP goals ? Have you read the click here link in my sig ? 60,000 miles on a stock ej257 at 21psi. It's all in the tune. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
