GEE-OTTO Posted September 4, 2015 Share Posted September 4, 2015 So recently my 2.5i has been having an issue with the brakes, not in performance but squealing. Very odd issue I'll drive and it's fine but after long highway trips when in slow down they start sealing and by they I mean the passenger front only. Also when I turn to the left the get louder but to the right it goes away and straight line driving the squeal is constant. First thought was sticking caliper so I took the wheel and looked at the rotor and it is worn but the pads are in decent shape. The was no play in the hub so I'm kinda stumped. Before I replace the rotors I wanted to get your opinions on the matter. Could this be a wheel bearing issue or a caliper issue? Link to comment Share on other sites More sharing options...
Wheelbuilder_25 Posted September 4, 2015 Share Posted September 4, 2015 Is one of the pads hanging in the carrier ? I've had the 'ears' of the pads bind on my old outback causing this. Sometimes you will see the pad wear at an angle, so one end is much lower than the other. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted September 4, 2015 Author Share Posted September 4, 2015 I will check thanks for that suggestion!!! Link to comment Share on other sites More sharing options...
NORULZleggy Posted September 4, 2015 Share Posted September 4, 2015 its the hub, mine is so damn loud, and doing the same thing your a describing. I am changing it in the morning, I will get pics. tomorrow. I have an 08 I with 143K. Link to comment Share on other sites More sharing options...
NORULZleggy Posted September 8, 2015 Share Posted September 8, 2015 GEE, I got my wheel bearing fixed this past Labor day weekend. did you check your out? My car is so quite now Link to comment Share on other sites More sharing options...
GEE-OTTO Posted September 10, 2015 Author Share Posted September 10, 2015 I think it's my bearing as well I ordered a new Timken hub and centric rotors Link to comment Share on other sites More sharing options...
NORULZleggy Posted September 10, 2015 Share Posted September 10, 2015 I just put on the Timken hub and Its a nice unit. I have Hawk HPS for front pads, Stoptech ceramic rear pads, Goodridge SS Brake lines, and StopTech F&R slotted rotors. The car stops like a dream. Let us know how your install goes. Did you order from Rockauto? Link to comment Share on other sites More sharing options...
GEE-OTTO Posted September 11, 2015 Author Share Posted September 11, 2015 Oh yeah rockauto.com all day! !! Link to comment Share on other sites More sharing options...
RustyRuu Posted September 14, 2015 Share Posted September 14, 2015 why dont you try greasing your breaking components first before springing for an new hub assembly its much cheaper. grease it all the slide pins behind the caliper clean them and grease them as well as anything would rub when you apply the brakes. caliper to pads and the little tabs on the pads as well. it would be a lot cheaper. like you said there is no play from the hub. Link to comment Share on other sites More sharing options...
NORULZleggy Posted September 16, 2015 Share Posted September 16, 2015 the hub it like 78 bucks, and it most likely the hub, mine was and I have everything greased on my car like crazy. It did not help. The Hub did. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted September 18, 2015 Author Share Posted September 18, 2015 Prior to this post I greased everything then went on a 400 mile road trip, the last 100 miles of that trip were so annoying every left turn or veering to the left resulted in louder sqealing. I figure the bearing will remain in tolerance for short trips but over a long distance and as it heats up it falls out of tolerance and allows the rotor to rub on the pad shims causing the squeal which is what they are supposed to do. I ordered a new Timken unit will install it soon. Link to comment Share on other sites More sharing options...
NORULZleggy Posted September 18, 2015 Share Posted September 18, 2015 Yeah, It drove me crazy for 3 months. I was in the process of selling a house and moving to a new town so I could not tear my car apart at the time. In the mean time my Outback's Alternator took a dump so I had to fix that also. It will be so quit when you get it fixed. :cheer: Now I can hear all the other not so bad noises. Link to comment Share on other sites More sharing options...
