tmgobxt Posted August 31, 2015 Share Posted August 31, 2015 It took a while but the 05 OBXT I got over a year ago is finally driveable. Piston 4 was fukd, ring land was gone. I decided to have a shop do everything since I don't have much time or tools at my disposal. It now has CP pistons and mahle rods along with a bunch of other supporting things. Lots of $ that's all I'll say for now. It has a vf52 for now due to budget reasons but that will change entually. In any case, I got a great dyno tune today by Matt Miner. Car made 288whp/310tq on a Mustang dyno, the turbo being the restriction. I'm happy I can actually drive this thing after over a year of ownership, now I get to focus on all of the other problem areas, mainly suspension. If anyone sees a white and loud outback wagon rolling around central mass give me a wave! Link to comment Share on other sites More sharing options...
Max Capacity Posted August 31, 2015 Share Posted August 31, 2015 Sounds like you had it done right. Have fun. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 31, 2015 Share Posted August 31, 2015 What exhaust mods did you do? Link to comment Share on other sites More sharing options...
tmgobxt Posted September 3, 2015 Author Share Posted September 3, 2015 What exhaust mods did you do? Stock headers, catless uppipe, catless turboback. I can't tell you what kind of exhaust it is since it was on the car when I got it when it was all shitty. It's a dual exhaust, with a resonator, mufflers on each tailpipe behind the rear bumper with turned down tips. It's very stealth looking. I was told that it's on the cheap side hence it's loudness. It's also missing some hanger points and will eventually rattle apart. After I get the suspension in good shape I'll figure out what's next for the exhaust setup. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 3, 2015 Share Posted September 3, 2015 I see. Did you take a look at the downpipe? Also, now that you have the car rebuilt, you should carefully monitor its parameters and stuff as you drive the car. I am using this btssm app designed by a fellow forum member. You will NOT regret this tool. It can save you an engine in the long run. --->http://legacygt.com/forums/showthread.php/btssm-bluetooth-adapter-app-229709.html Link to comment Share on other sites More sharing options...
