StarterGang Posted August 25, 2015 Share Posted August 25, 2015 i just bought this 06 Legacy GT Limited a couple of months ago with 130k and i noticed that it binds at low speeds(it only binds after you drive the car after a while) I took it to a couple of shops and one guy told me the problem was in the transfer case, another shop told me that manual transmissions doesn't have a transfer case and the problem is coming from a clutch solenoid in the transmission... i have no clue whats going on all i know is my warranty is up soon and i need to figure out what is causing this binding since i can't really find anyone else online with the same problem.. at least for my generation LGT Link to comment Share on other sites More sharing options...
Max Capacity Posted August 25, 2015 Share Posted August 25, 2015 Have the second guy fix your problem. Where do you live ? may be we can tell you where to take it. I gather the car is a 5eat tranny ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
WaNtEdAmErIcAn Posted August 25, 2015 Share Posted August 25, 2015 Try changing (NOT FLUSHING) the transmission fluid once of twice. My first legacy (a 95) would always bind at low speeds when I was turning. I changed the transmission fluid and it was fixed. Link to comment Share on other sites More sharing options...
StarterGang Posted August 26, 2015 Author Share Posted August 26, 2015 Its a 5spd manual ... I would have the second guy do it but he requires a $1500 deposit incase the warranty doesnt pay for it he did also recommend a tranny fluid change though it just weirds me out how uncommon this is for 4th gen lgt Link to comment Share on other sites More sharing options...
snm95ls Posted August 26, 2015 Share Posted August 26, 2015 There are no clutch solenoids for the 5MT unless someone managed to swap in a 5MT with DCCD...which is pretty unlikely. Binding at low speeds sounds like a center differential issue. Link to comment Share on other sites More sharing options...
apexi Posted August 26, 2015 Share Posted August 26, 2015 Before you go too far I'd be curious to know what the tread depth for all four tires is. It is possible there is a problem with your transmission, but I would rule out the tires first. *Just to elaborate on what I'm getting at, the link below has more information. http://www.subaruoutback.org/forums/66-problems-maintenance/30110-tire-circumference-spec-confirmed-subaru-techtips.html Link to comment Share on other sites More sharing options...
