garageboy Posted August 23, 2015 Share Posted August 23, 2015 Looking at an 06 Legacy. 105k. Owner says "The car makes a little irritating sound when driving super slow but NOT when driving average speeds or free way speeds. Mechanic quoted it to be 'heat shield' problem and it costs less than 60$ to fix/repair it. " My questions are: 1. Could this really be the heat shield? Or something more involved? 2. If it really is the heat shield, is $60 a fair repair estimate? Owner replaced the engine oil, transmission oil, rear and front differential fluids ( for AWD), washer fluid and steering fluids and changed the rear disc brakes and rotors, Timing Belt, Tensioner, Water Pump, and Timing Belt Cover. Thank you very much. Link to comment Share on other sites More sharing options...
uptown4784 Posted August 24, 2015 Share Posted August 24, 2015 yeah sounds like is a heat shield. This usually happens a lot with a legacy. The dealer was going to charge me 20 bucks. but I told them no so they did it for free Link to comment Share on other sites More sharing options...
Ellesedil Posted August 24, 2015 Share Posted August 24, 2015 If it's only 60 bucks, why can't the owner fix it before selling you the car? Link to comment Share on other sites More sharing options...
garageboy Posted August 26, 2015 Author Share Posted August 26, 2015 That's what I think, Ellesedil. Thank you. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 26, 2015 Share Posted August 26, 2015 Depends on which heat shield is making the noise. I have a few of mine removed. They don't make noise anymore. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted August 26, 2015 Share Posted August 26, 2015 large strap will fix any noise they make. Honda used to do it to all of their 4cyl rattle can accords that buzzed around 2Krpm Link to comment Share on other sites More sharing options...
