CT05Legacy Posted August 21, 2015 Share Posted August 21, 2015 Does anyone have any company23 tools for loan? Looking for the crank pulley, int sprocket, and exh sprocket tools. Maybe the camlock as well. Thanks. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 21, 2015 Share Posted August 21, 2015 Is your car a manual or automatic? Link to comment Share on other sites More sharing options...
doobaruGT Posted August 23, 2015 Share Posted August 23, 2015 I have the cam wrench, but I misplaced the cam lock tool. I'll see if I can track it down and get back to you. Sent from my iPhone using Tapatalk Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 24, 2015 Share Posted August 24, 2015 btw, I asked what type of trans you have, cause if you have a manual, you can do the following: -for crank pulley, just put it in 5th gear, with parking brake on and loosen the bolt. I did this more than 5 times. Always works. -for int/exh cam pulleys, you can do this (regardless of trans type): This morning, quickly pulled out timing belt, and began taking off the cam sprockets using the timing belt trick to hold them into place. Intake cam sprocket came off without too much trouble. And of course, exhaust cam is not coming off. Even though I was really careful, the cam bolt slowly got damaged . Bolt material is way too soft. Will have to use some bolt extractor technique or whatever method to get that sucker off. I knew this was coming.. More updates soon. http://legacygt.com/forums/attachment.php?attachmentid=210641&d=1434217128 Well, great news: exhaust cambolt came off using a bolt extractor from HF ($23 the set). Used 11/16 size. Had to grind a bit the bolt using a dremel. And then, tapped the bolt extractor, used breaker bar and voila! It was not too bad. Happy to report this method works great. http://legacygt.com/forums/attachment.php?attachmentid=211073&d=1434630867 http://legacygt.com/forums/attachment.php?attachmentid=211074&d=1434630867 Link to comment Share on other sites More sharing options...
CT05Legacy Posted August 25, 2015 Author Share Posted August 25, 2015 Is your car a manual or automatic? Auto Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
CT05Legacy Posted September 16, 2015 Author Share Posted September 16, 2015 I have the cam wrench, but I misplaced the cam lock tool. I'll see if I can track it down and get back to you. Sent from my iPhone using Tapatalk doobaruGT, any luck? Still willing to loan? Link to comment Share on other sites More sharing options...
elitetux Posted September 17, 2015 Share Posted September 17, 2015 I have the Company23 camlock tool and a grimmspeed crank pulley removal tool. Link to comment Share on other sites More sharing options...
doobaruGT Posted September 17, 2015 Share Posted September 17, 2015 doobaruGT, any luck? Still willing to loan? I have my wrench but I can't find the cam lock tool:mad:. I think I'll buy another since they're handy for timing belts. If you'd like, I can loan you the wrench. PM me for terms. If you're willing to wait a few days I can lend you both after I buy another lock tool. Let me know what you'd like to do. It's better to pm me since that gets forwarded to my email. Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
doobaruGT Posted September 19, 2015 Share Posted September 19, 2015 Update: bought another lock tool. Should be here Tuesday Sent from my iPhone using Tapatalk Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
doobaruGT Posted October 1, 2015 Share Posted October 1, 2015 Haven't heard from you. Let me know if you'd still like to borrow the tools. Sent from my iPhone using Tapatalk Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
