whitrzac Posted August 9, 2015 Share Posted August 9, 2015 Has anyone else had an issue with aftermarket CVs ripping the outer CV boot? I've had 2 CVs boots rip on the outer passenger side in the past 3 months:confused: Link to comment Share on other sites More sharing options...
Max Capacity Posted August 9, 2015 Share Posted August 9, 2015 That side inner boot is the normal problem child. Your just getting a cheap after market axle ? Better luck with the next one. FWIW I just had both boots replaced on my OEM axle on that side with OEM boots. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rmoore5 Posted August 9, 2015 Share Posted August 9, 2015 Has anyone else had an issue with aftermarket CVs ripping the outer CV boot? I've had 2 CVs boots rip on the outer passenger side in the past 3 months:confused: I'm going to post a Subaru OEM outer that I didn't wind up using in the for sale section. Link to comment Share on other sites More sharing options...
