08_GT Posted August 6, 2015 Share Posted August 6, 2015 Hey guys just a few questions, im new to Subaru so I'm not super familiar with these cars but I own a 08 legacy gt 5EAT. Im coming from toyota/lexus, had a few sc300's and still love them, just wanted to try something different and newer. Didn't want a wrx since everyone has one, I like different so the legacy was perfect. Anywho my ultimate goals for this car will be a 500+ 10sec street car. For now itl be keeped fairly stock with nothing to crazy. So here we go .TMIC vs FMIC? I'm looking to do supporting mods than I can keep when I throw in the bigger turbo. So my questions is -What is the largest turbo that can be fitted in the stock location and still retain a TMIC? Also Im not sure if different coolers have different amounts of clearance? -Seems like a FMIC is the way to go since it's clears up the entire.area to mount a customer bigger set up. But I don't see purpose for all the xtra piping, I rather keep it short and neat. I simply love the look of the tmic. -As far as cooling efficiency. At what level does the FMIC become "Way" more efficient than a tmic? Other than that im sure I can figure out the rest. Those are just the things that are rolling in my head atm. I appreciate any help that I can get and thanks again guys. I look forward to messing the legacy. Link to comment Share on other sites More sharing options...
boxkita Posted August 6, 2015 Share Posted August 6, 2015 Hope you got lots of cash. 500hp is not a 10sec car, tho Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
boxkita Posted August 6, 2015 Share Posted August 6, 2015 Tmic is definitely the best for 500hp streetable power too. The fmic overheats too much and really doesn't have much benefit until pushing 1000hp Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
whitetiger Posted August 6, 2015 Share Posted August 6, 2015 Link to comment Share on other sites More sharing options...
GTEASER Posted August 6, 2015 Share Posted August 6, 2015 just WOW! GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
08_GT Posted August 6, 2015 Author Share Posted August 6, 2015 Goal is a 10 sec. In the long run. 500+ is a number. This isn't happening tomorrow. Were not kids here. Il be searching the info, was just hoping I could get some input. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 6, 2015 Share Posted August 6, 2015 http://legacygt.com/forums/showthread.php/awdtuning-makes-711whp-2-5l-legacy-specb-borg-warner-efr9180-237738.html read that for starters. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
08_GT Posted August 6, 2015 Author Share Posted August 6, 2015 Thanks for that Il give a look. Obviously the car will be built in the future to handle the power. If anyone can maby give me a list of aftermarket turbos that can be fitted in the stock location. Thanks Link to comment Share on other sites More sharing options...
GTEASER Posted August 6, 2015 Share Posted August 6, 2015 That's definitely the place to start. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Max Capacity Posted August 6, 2015 Share Posted August 6, 2015 With a good Fab guy most any turbo can fit. There are a few guy's here that have rotated set ups. m sprank may be a good member to look up. But he owns a real shop so make sure you know what your talking about so you don't take up to much of his time. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
boxkita Posted August 6, 2015 Share Posted August 6, 2015 Goal is a 10 sec. In the long run. 500+ is a number. This isn't happening tomorrow. Were not kids here. Il be searching the info, was just hoping I could get some input. Sure sounds like a kid question. High hp builds start with a goal then reality sets in when numbers are attached. A big turbo will suck on the street unless you use a high rpm torque converter. standard auto tragic redlines at 5k. You really want a drag car get a wrx. You'll be money ahead Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
whitrzac Posted August 6, 2015 Share Posted August 6, 2015 There's a thread on here where someone tried to do just this. IRRC he's on engine #4. Your auto tranny will not hold up. There's nothing you can do to the 08-09 ones to make them more durable. Link to comment Share on other sites More sharing options...
08_GT Posted August 7, 2015 Author Share Posted August 7, 2015 Sure sounds like a kid question. High hp builds start with a goal then reality sets in when numbers are attached. A big turbo will suck on the street unless you use a high rpm torque converter. standard auto tragic redlines at 5k. You really want a drag car get a wrx. You'll be money ahead Don't worry, I know it can be done and with time it will be done. Just trying to clear up some questions. Thanks for the input guys, for now the car will running a vf52 til I can figure out what turbo I want to end up with. Looks like I have to get a custom set up? I was considering a borgwarner turbo since I've had experience with them and there probably the best bang for your buck. If there a log on how much more a FMIC out performs a aftermarket tmic? So I can get an idea Thanks again Link to comment Share on other sites More sharing options...
ras06LGT Posted August 7, 2015 Share Posted August 7, 2015 ...Looks like I have to get a custom set up?... Yes, getting to a 10 second LGT will require a VERY custom set-up. The LGT is really not the right platform for these kind of goals. Link to comment Share on other sites More sharing options...
Flinkly Posted August 7, 2015 Share Posted August 7, 2015 I suggest you sell your autotragic and get a manual. A specb would be the smartest, if you are really trying to do any of what you're talking about with a legacy. Good luck and see ya in the #ynansb forum. Sent from my XT1028 * Build Thread * 26.53 MPG - 12 month Average * Link to comment Share on other sites More sharing options...
boxkita Posted August 7, 2015 Share Posted August 7, 2015 Don't worry, I know it can be done and with time it will be done. Just trying to clear up some questions. Thanks for the input guys, for now the car will running a vf52 til I can figure out what turbo I want to end up with. Looks like I have to get a custom set up? I was considering a borgwarner turbo since I've had experience with them and there probably the best bang for your buck. If there a log on how much more a FMIC out performs a aftermarket tmic? So I can get an idea Thanks again Seriously? you're not getting it. Wrong car. A wrx or sti is much better platform. unless you have lots of money. It sounds like are going to hire it out. So find a builder and setup a payment plan. You'll get a great build. Stoopid expensive but running. Tmic is good for 350 maybe. A fmic double that. A rotated intake with a front mount turbo ? Probably 1000 Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
boxkita Posted August 7, 2015 Share Posted August 7, 2015 Build a couple of engines too. That way you can have street motor and a drag motor Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
boxkita Posted August 7, 2015 Share Posted August 7, 2015 Heck im in the middle of what's turning into a complete rebuild. I'll add some extra stuff. You should be able to get into the 9's. It already was capable of 11s. buy it now for 20k. Or fully assembled for 50k Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
08_GT Posted August 7, 2015 Author Share Posted August 7, 2015 Seriously? you're not getting it. Wrong car. A wrx or sti is much better platform. unless you have lots of money. It sounds like are going to hire it out. So find a builder and setup a payment plan. You'll get a great build. Stoopid expensive but running. Tmic is good for 350 maybe. A fmic double that. A rotated intake with a front mount turbo ? Probably 1000 Coming out a little to aggressive but I get point. I know itl be costly. Thanks for the info it's what I'm looking for. I was simply asking if the tmic was efficient enough for higher hp build or if the fmic was "mandatory". I didn't how bad the tmic really really was. But I just had to confirm it. Not to worry, like I said the car isn't being built overnight. As of now I'm only shooting for 300whp on the vf52 then slowly progressing. I like the different factor In the legacy. I can almost guarantee that im the only gt owner in my city. Every one with a subaru out here is literaly a wrx. I know a thing or two when it comes to building cars. Had a few 2j and 1jz motors. Have worked a fair share of 4g63s and ls1's as well. Link to comment Share on other sites More sharing options...
08_GT Posted August 7, 2015 Author Share Posted August 7, 2015 I do have another question for you if you dont mind How far will a accessport take you? Is it considered a piggyback or is it comparable to what a standalone ecu could do? Link to comment Share on other sites More sharing options...
Max Capacity Posted August 7, 2015 Share Posted August 7, 2015 Stage 2 is where Cobb takes you. Anything after that you use it so the Tuner can load a map into it and then load it into the ecu. Talk to the guy's and girls at AWDtuning in TX 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
battelready Posted August 7, 2015 Share Posted August 7, 2015 Hope you know the tranny cant handle much after 350-400 and its recommended to get your valve body modified as well a trans cooler to go over 300 whp I bought an auto be more involved in my uninvolvedness . 200k+ Club If you can't blind them with brilliance, baffle them with bullshit. My high mileage turd. Link to comment Share on other sites More sharing options...
whitrzac Posted August 7, 2015 Share Posted August 7, 2015 Hope you know the tranny cant handle much after 350-400 and its recommended to get your valve body modified as well a trans cooler to go over 300 whp Which he can't do be cause it's an 08-09 car. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 7, 2015 Share Posted August 7, 2015 Oh yea its a 5eat, no way he'll ever get close to that HP for very long. May be he can put a Chevy tranny in it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Mike07LGT Posted August 7, 2015 Share Posted August 7, 2015 I had a Forced performance "red" turbo stock location on my sti, made 486 wheel horsepower on Q16 race gas running 32 psi and could only manage an 11.6 time slip. I also put 40 grand + into that car so I hope you have a seriously good paying job and best of luck to you! We have yet to see a legacy street car break into the 10s... 03 WRB WRX (RIP) 04 JBP STI (sold) 07 DGM Legacy GT (RIP) 12 OBP STI (DD) Link to comment Share on other sites More sharing options...
