gto7419 Posted August 4, 2015 Share Posted August 4, 2015 Just an FYI, the eBay exhaust from cx racing no longer comes with a resonator in the midpipe. It bolts up fine - even on my obxt, but the muffler tips are pressed into the bottom of the rear muffler. Pretty sure its going to melt if I leave it like that so I'm debating cutting off the tips and welding some "downspouts" on. Link to comment Share on other sites More sharing options...
lingling1337 Posted August 4, 2015 Share Posted August 4, 2015 Would xl hangers help to lower the exhaust any? I was a little annoyed that theres no resonator too, so my cheapest option for a resonated midpipe starts at $550 now Link to comment Share on other sites More sharing options...
gto7419 Posted August 4, 2015 Author Share Posted August 4, 2015 I'm sure that longer hangars would work. Link to comment Share on other sites More sharing options...
Adamn Posted August 5, 2015 Share Posted August 5, 2015 Try loosening everything up and tightening the mufflers first then working your way towards the front of the car. When I did that it seemed to somehow pull the tips away from the bumper just slightly enough to have them not touch. That and adding the hose clamps to the hangers pulled it away enough that it didn't touch. This at least worked for the Legacy, not sure how much it will help you. Still ended up being too loud for me with the hollow mufflers so I bolted the stocks back on. Can't even tell I have the new mid and y pipe on there now it's so quiet. Link to comment Share on other sites More sharing options...
kongzilla Posted August 5, 2015 Share Posted August 5, 2015 did you buy a wagon or outback exhaust as there is a difference in tips. Link to comment Share on other sites More sharing options...
gto7419 Posted August 5, 2015 Author Share Posted August 5, 2015 The eBay exhausts come in one variety. Legacy gt. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 7, 2015 Share Posted August 7, 2015 You can put a screw type hose clamp around the rubber hangers and tighten the clamp to move the exhaust. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
gto7419 Posted August 10, 2015 Author Share Posted August 10, 2015 Im trying to move the cans down. Im going to end up buying some longer rubber hangers and call it a day. I debated cutting the tips off and welding on downturns, but thats a lot of work and I really dont care that much. Link to comment Share on other sites More sharing options...
