Jdubgt530 Posted July 26, 2015 Share Posted July 26, 2015 So I got my new heads and headgaskets together. I bolted down everything correctly. When I fired it up to start burping the system I put oil in it before hand. I have a ej25 and I put 4.25 quarts of oil into it. When I started to drive I got this weird clacking noise that sounds like the engine doesn't have enough oil but when I check it its at the perfect level. Link to comment Share on other sites More sharing options...
subieadam Posted August 1, 2015 Share Posted August 1, 2015 New heads? Are the valves adjusted properly? Link to comment Share on other sites More sharing options...
Flinkly Posted August 1, 2015 Share Posted August 1, 2015 What rod cap bolts did you use? Oem or aftermarket? Sent from my XT1028 * Build Thread * 26.53 MPG - 12 month Average * Link to comment Share on other sites More sharing options...
Jdubgt530 Posted August 1, 2015 Author Share Posted August 1, 2015 Yeah new heads are in and they had a valve job done. Found out it was an exhaust leak coming from my exhaust manifold. A bolt I put on fell off so I got a new one and torqued that down Link to comment Share on other sites More sharing options...
