dustinsonger Posted July 21, 2015 Share Posted July 21, 2015 (edited) So i figured a new thread is due. been gone awhile. little problems, as they like to do, kept piling up and kept this thing off the road for far too long. But shes back on the road and has been tearing up mountain passes already with some new goodies. I spend alot of time and am proud to say that everything but the machine work was done by myself. mods list i guess? Engine: heat treated sti crankshaft King bearings custom Manly rods (2mm longer than stock) JE "time attack" series "stroker" pistons (99.75 bore) GSC valves (inconel exhaust) Tomei adjustable exhaust cam gears Arp head studs Gates racing timing belt Tomei timing belt guard custom hi flow oil pump Injector Dynamics 850cc injectors Turn in Concepts FU cam bolts KS Tech TGV delete KS Tech Air Pump delete Moroso Steel oil pan Moroso Oil pickup Borla Unequal Length header VF52 turbo custom 3 inch downpipe custom 3 inch exhaust ACT streelight flywheel Southbend endurance clutch AVO after-maf inlet AVO turbo inlet AVO throttle body inlet Big top mount intercooler that i got from my ex and i cant remember the brand Drivetrain: stuff to make big tires work Suspension: Stuff to work with my big tires Wheels: Things to hold my big tires Tires: wide Aero: alot of stuff to make my tires stick better Edited July 23, 2015 by dustinsonger Link to comment Share on other sites More sharing options...
rebourne Posted July 21, 2015 Share Posted July 21, 2015 Holy Fuuuuh! pic thread build thread Link to comment Share on other sites More sharing options...
Nightmaresmk Posted July 21, 2015 Share Posted July 21, 2015 Ok so details on the suspension and about time you updated. us crazy outbacks like ot see other crazy outbacks. lol Link to comment Share on other sites More sharing options...
dustinsonger Posted July 21, 2015 Author Share Posted July 21, 2015 Ugh haha. Well I've got some custom bits, some avo stuff, some other companies stuff, and some custom valved dampeners and if ill be specific on something ive got 8k springs up front and 10k springs in back. Suspension stuff is being adjusted and rethought almost daily at this point. I know the feeling I'm going for and I'm getting close but it has not quite been reached yet. Link to comment Share on other sites More sharing options...
kaitanium Posted July 22, 2015 Share Posted July 22, 2015 a little crazy looking but im sure its crazy fast =D Is that thing poking out of the bumper your exhaust?? Link to comment Share on other sites More sharing options...
dustinsonger Posted July 23, 2015 Author Share Posted July 23, 2015 Yes haha that is my exhaust. here's some better pictures that show the dual deck diffuser and exhaust i built for it Link to comment Share on other sites More sharing options...
Nightmaresmk Posted July 23, 2015 Share Posted July 23, 2015 Your car is different but when it's all about function it would be. are you going to roll cage it and run it as more of a track car? Maybe go for twin peaks hill climb or something. Link to comment Share on other sites More sharing options...
dustinsonger Posted July 23, 2015 Author Share Posted July 23, 2015 Pikes peak and the full red line season where the goal for this year but the engine build got out of control and tapped into all my funds for a roll cage and the other safety stuff need for pikes peak. And the engine build took too long to make it to any of the red line events. But yes that is definitely the goal Link to comment Share on other sites More sharing options...
boxkita Posted July 24, 2015 Share Posted July 24, 2015 The "catfish" lives ! Great to see it back on the road. Luv the center exhaust Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
dustinsonger Posted July 24, 2015 Author Share Posted July 24, 2015 Holy crap, sir boxkita. I was hoping you would still be active here haha. And no one "likes" the center exhaust haha, but it's the most simple way I could attempt the "dual deck blown diffuser" I've been ranting about for years now haha Link to comment Share on other sites More sharing options...
boxkita Posted July 24, 2015 Share Posted July 24, 2015 Holy crap, sir boxkita. I was hoping you would still be active here haha. And no one "likes" the center exhaust haha, but it's the most simple way I could attempt the "dual deck blown diffuser" I've been ranting about for years now haha What do they know? Do you have pics of the inside where you had to cut out the tire well, assuming that's what you did? Last time we talked about that, I thought you were going to pipe it into the diffuser for a "true" blown thru diffuser? Or did that turn out to be way complex? Do you have video either of sound and/or rolling shots? How does the rear end do on corners? Sgt.Gator did the wing on top at the rear axle. Would be curious who's make more downforce on the rear. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
kaitanium Posted July 24, 2015 Share Posted July 24, 2015 im curious, how do you know all those panels actually work? Link to comment Share on other sites More sharing options...
rebourne Posted July 24, 2015 Share Posted July 24, 2015 Well, before Formula One level telemetrics existed, there was the usual method: Car goes faster in the corners. pic thread build thread Link to comment Share on other sites More sharing options...
dustinsonger Posted July 24, 2015 Author Share Posted July 24, 2015 (edited) Well honestly that was the original plan boxkita, after I got a chance to really sit down and focus on the diffuser design I really kept coming back to the number one problem with wagons (or hatches or vans) and that is that behind the car, it's very hard to keep a smooth flow of air off of the body, since the back creates a huge parachute like spot of low pressure. So my thinking was, let's use the diffuser to open up a slightly low pressure spot just behind the axle, by bringing the upper deck of the diffuser up higher than the plane of flow under the car, then I will separate the turbulent air from behind the tires from the relatively smooth airflow coming out from either side of the driveline run. Keep that open for a punch of faster air coming into the stream behind the car, then I used the center section to form the lower deck that sits at a relatively high angle of attack to produce some downforce BUT also work in conjunction with theach hot high velocity air coming out from the exhaust directly above it to essentially drive a high pressure front into the low pressure area created by the hatch area... or that was my thinking at least. And kaitanium, to be honest I don't know if they do anything or not but I use this car as a testbed for what I study in fluid dynamics and engineering Edited July 25, 2015 by dustinsonger Link to comment Share on other sites More sharing options...
dustinsonger Posted July 29, 2015 Author Share Posted July 29, 2015 So the ecu is fried... so while I wait for a new one I figured time to check ALL the wiring... Link to comment Share on other sites More sharing options...
dustinsonger Posted August 7, 2015 Author Share Posted August 7, 2015 random little things getting done. Link to comment Share on other sites More sharing options...
Nightmaresmk Posted August 8, 2015 Share Posted August 8, 2015 Nice good luck. Link to comment Share on other sites More sharing options...
dustinsonger Posted August 10, 2015 Author Share Posted August 10, 2015 well new ecu seems fine but my car is a fricken loner and wont talk to any computers... even subarus. so im just out of ideas and, for the moment at least, f***s to give Link to comment Share on other sites More sharing options...
Nightmaresmk Posted August 11, 2015 Share Posted August 11, 2015 Our ecu's have a security piece check the build section for information. Link to comment Share on other sites More sharing options...
dustinsonger Posted September 4, 2015 Author Share Posted September 4, 2015 does anyone have a biu (immobolizer) laying around i could buy or bum? Link to comment Share on other sites More sharing options...
Nightmaresmk Posted September 4, 2015 Share Posted September 4, 2015 Contact PMP in Penn. I have gotten a few things off them. Link to comment Share on other sites More sharing options...
bikerx500 Posted September 6, 2015 Share Posted September 6, 2015 here is the link for them. its funny since im about 10-15 minutes from them lol http://pmpautogroup.com/public/ Link to comment Share on other sites More sharing options...
Slusbe Posted September 7, 2015 Share Posted September 7, 2015 I love how balls-to-the wall this build is. I am curious how much daily usability you intend to retain? There are a ton of things you could probably do if you give up passenger car functions. How far are you planning to go? Either way I love the experimental nature to it. I wonder if there are some old-school methods of racecar engineering you could apply to generate some actual testing data. Like how much downforce is being generated in the back by monitoring ride height change at speed, etc. I really should read up more about racecar development. Link to comment Share on other sites More sharing options...
s2baru Posted September 8, 2015 Share Posted September 8, 2015 What's the wheel and tire specs you have tucked under there? Link to comment Share on other sites More sharing options...
dustinsonger Posted September 9, 2015 Author Share Posted September 9, 2015 Thanks for the recommendation guys. and thanks slusbe. i really shouldnt be driving the car on the street at all but i do, when im not having electrical problems from hell at least. the car is fully usable on a daily basis, its part of the whole awkwardness of the car, full interior and a nice jl system since thats what i do for a living haha. and yes there are ways to test the effectiveness of aero, mainly with small high airspeed pressure sensors. and s2baru, there is definitely nothing tucked about my car haha but the tires are 295's Link to comment Share on other sites More sharing options...
