Nightmaresmk Posted June 7, 2016 Share Posted June 7, 2016 Any more updates? for those who don't use instagram. Link to comment Share on other sites More sharing options...
dustinsonger Posted August 12, 2016 Author Share Posted August 12, 2016 boy i guess i should maybe let you guys know this things been alive again for a couple months Link to comment Share on other sites More sharing options...
Smithcraft Posted September 3, 2016 Share Posted September 3, 2016 After reading the first thread, I'm glad this car is continuing! SC 1994 Legacy MI 2008 Legacy GT specB 2023 Crosstrek Limited Link to comment Share on other sites More sharing options...
famaya26 Posted September 3, 2016 Share Posted September 3, 2016 This is a cool looking wagon Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Rhitter Posted September 7, 2016 Share Posted September 7, 2016 @ Dustin, have you considered doing a heat extractor hood set-up similar to SGT.Gator. My OBXT build Link to comment Share on other sites More sharing options...
magnusonsubie Posted September 8, 2016 Share Posted September 8, 2016 @ Dustin, have you considered doing a heat extractor hood set-up similar to SGT.Gator. He's still topmount otherwise I'd suggest that as well. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
Rattsl Posted September 9, 2016 Share Posted September 9, 2016 Love this thing. Link to comment Share on other sites More sharing options...
dustinsonger Posted September 10, 2016 Author Share Posted September 10, 2016 Thanks guys! always nice to know people still like this thing. And @rhitter like @magnusonsubie said im still topmount so no hood venting yet. But i have been playing with the idea of dumping post radiator air out the hood somehow but i dont want it to just get dumped right back into the top mount so i have to work out ducting and vent placement. To update though ive finally gotten around to ordering a few parts though to finish up for the summer, proper afr for the ecu to read and some minor stuff so we can finalize the tune for now. also im getting closer to finishing my stereo for it. soon ill get around to finishing the rest of the box so it houses the amp and crossovers and processor and whatnot. All jl audio stuff. HD900/5 amp, c5-650 front speakers, cleansweep processor, bluetooth module, and 2 10 w6v3's. Its definitely not done yet. have some fun stuff for two more speakers and still have to wrap the box and lay laminate and whatnot on it but i do it in my spare time and this is everything that will be put in the rear section of the box Link to comment Share on other sites More sharing options...
dustinsonger Posted September 16, 2016 Author Share Posted September 16, 2016 Doing some maintenence/upgrades/prep for winter to the outback. Proper afr meter, new gauge, end links that I've need for years now, various gaskets, and I'm making a "gauge pod" that will mimic the look of the factory cluster surround hump thing off to the right of the cluster. Also taking the splitter and diffuser off for the winter Plus a couple pictures of rarely seen parts of the wagon haha Link to comment Share on other sites More sharing options...
rebourne Posted September 16, 2016 Share Posted September 16, 2016 Plus a couple pictures of rarely seen parts of the wagon haha these edit: I see dead skateboards. pic thread build thread Link to comment Share on other sites More sharing options...
dustinsonger Posted September 24, 2016 Author Share Posted September 24, 2016 edit: I see dead skateboards. Haha just two heavily used ones. I flipped the trucks on one to make a slammed skateboard. Link to comment Share on other sites More sharing options...
dustinsonger Posted December 30, 2016 Author Share Posted December 30, 2016 got bored and decided to park the wagon and take care of some stuff on it since the winter here in northern wyoming is nuts this year. Got a proper aos, made a turbo heat shield, replaced a coil pack, new plugs, and i decided to finally get rid of the stock airbox. Got a cobb sf intake but decided to hand fabricate my own airbox. Link to comment Share on other sites More sharing options...
dustinsonger Posted December 30, 2016 Author Share Posted December 30, 2016 So once i finished up the airbox, had to decide how to get air in, so... Screw my high beam haha. chopped the headlight, made an endcap out of fiberglass, sealed it all up, made some brackets and a ramp and there ya go Link to comment Share on other sites More sharing options...
Rhitter Posted May 25, 2017 Share Posted May 25, 2017 Any updates? My OBXT build Link to comment Share on other sites More sharing options...
xtea Posted May 26, 2017 Share Posted May 26, 2017 (edited) I got one degree below ambient today with just my intake in the wheel well. I love what you did but.... maybe excessive? Excellent execution though. Edit: I just read through the thread and though the pictures don't work, clearly Excessive is the theme. I did notice though that with cold air intakes you may need to create an exit path for the high pressure air if you are hellbent on achieving the coldest intake temps possible. That way you constantly have access to air that has spent as little time in the low pressure area as possible. (I'm not an engineer). I tried a one way sealed box like yours and temps actually went higher then just filter in the fender well. Edited May 26, 2017 by xtea Link to comment Share on other sites More sharing options...
dustinsonger Posted May 27, 2017 Author Share Posted May 27, 2017 (edited) good info xtea, i haven't really had much chance to do any real testing on it but ill get some numbers sometime with different setups. And haha yeah a couple updates from the last couple months. this happened alittle over a month ago so that was pretty awesome Edited May 27, 2017 by dustinsonger Link to comment Share on other sites More sharing options...
dustinsonger Posted May 27, 2017 Author Share Posted May 27, 2017 broke my fancy headlight, broke the mounting tab on the radiator, popped the ac condenser, bent up the radiator support and fucked up the hood a bit. Luckily USAA took pretty good care of me, so i got a koyo radiator, new supports, a new condenser, a new headlight (just a tyc because i was going to cut it anyways), and a new hood, and also picked up some suspension goodies i've been waiting forever to have the extra money to do Link to comment Share on other sites More sharing options...
dustinsonger Posted May 27, 2017 Author Share Posted May 27, 2017 (edited) I should add, im not living in the same place anymore so i dont have a shop below my house anymore so shit will not be happening at a crazy pace anymore, took me a few weeks to find all the time to do everything, have basically everything done now, just need to get the new hood painted sometime. did the rear LCA's and the upper bushings back there, and did the front ALK and bushings. tightened up the car so much and she is so much more behaved now. Also, holy shit i cant say it enough, there is nothing i have done to my car that has made a more noticeable improvement across the board than doing whiteline's street Anti lift caster kit. the tires have been changed since this picture was taken. dont reqally have any of the front stuff cuz its boring to look at Edited May 27, 2017 by dustinsonger Link to comment Share on other sites More sharing options...
ItalianPasta Posted October 4, 2017 Share Posted October 4, 2017 update? Link to comment Share on other sites More sharing options...
dustinsonger Posted January 13, 2018 Author Share Posted January 13, 2018 Well I have not really been up to anything, had an scare happen last week when the turbo seals gave out but just got a new chra for the vf52. About time to step up to a proper sized turbo soon but wasnt ready for it atm. Outside of that, shes in full winter/outback mode and just enjoying the nice (read: cold af, but finally snowy) winter we are having here in northern wyoming this year Sent from my VS988 using Tapatalk Link to comment Share on other sites More sharing options...
dustinsonger Posted January 14, 2018 Author Share Posted January 14, 2018 Oh yeah I also picked up two nice cree led 5.6 inch motorcycle headlights and mounted them in the factory fog light holes, flippin amazing output, far better than the factory ever have been and I even have a high beam in my fog lights haha Sent from my VS988 using Tapatalk Link to comment Share on other sites More sharing options...
boxkita Posted May 27, 2021 Share Posted May 27, 2021 bumpskis Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
dustinsonger Posted July 5, 2021 Author Share Posted July 5, 2021 Just on a base map but running fine with the setup I built. Mr2 really needed attention so it's just getting me around right now. I've been wanting to put together more of the videos from the build but just haven't had the timehttp://cloud.tapatalk.com/s/60e35de592705/20210705_131838_1_960x540.mp4 Sent from my SM-G991U using Tapatalk Link to comment Share on other sites More sharing options...
rebourne Posted July 6, 2021 Share Posted July 6, 2021 That hood pop and huge turbo was a surprise! pic thread build thread Link to comment Share on other sites More sharing options...
boxkita Posted July 6, 2021 Share Posted July 6, 2021 the carfish never fails to deliver. That turbo! Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
