discojon Posted July 6, 2015 Share Posted July 6, 2015 My used borla header has finally bit the dust, the pipe cracked almost halfway around on one bank. I was able to weld it back up and get airtight but I know its just a matter of time till it goes again. I found the M2 performance equal length on eBay and figured I'd give them a shot. I think eventually I'll end up with a set of Perrin's or killer B's but until then I'm hoping these will get me by. Anyone used these before? And I'm going to use new GS gaskets not the one it ships with. Link to comment Share on other sites More sharing options...
whitrzac Posted July 6, 2015 Share Posted July 6, 2015 I've read bad things about the cheap headers that use flexy joints. The flex joints are sub-par and disintegrate, sending metal bits through the turbo. I bought one of these. http://www.ebay.com/itm/321779217954?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT Link to comment Share on other sites More sharing options...
starionesir Posted July 6, 2015 Share Posted July 6, 2015 On a daily driver headers are always going to be a problem with cracking. Everytime I'm at my local tuning shop there's cars with cracked headers/up pipes. I too have a cracked up pipe. I'd stick with oem or jump up to a much higher end header. Killer B or full race. Not cheap by any means but have never seen one crack. Link to comment Share on other sites More sharing options...
discojon Posted July 6, 2015 Author Share Posted July 6, 2015 After more research, I have cancelled that order and picked up a GS High Flow crosspipe. I'm going to port match the other pipes to the GS cross and Uppipe. I ordered a carbide porting set and several flapper wheels and hopefully that will be enough. I don't plan on wrapping the manifold but i am going to sandblast and paint / coat the end pipes. Link to comment Share on other sites More sharing options...
