Bobbo63 Posted June 29, 2015 Share Posted June 29, 2015 Please dont assume since i dont know the names of parts that i dont understand their function. My A/C dont work, and ive traced the problem to the switch on-top of the beer can lookin thing, with the small glass window with the 2 aluminum tubes goin into it, on the passengers side near the firewall. Does that narrow down what im talkin about? Whats that switch called and where do i get one. A/c clutch wont engage unless i bypass it the switch. I got power into the switch, but not out. Sounds like the switch to me. However... i cant seem to find one on amazon/napa/schucks/oriley/autozone... Anybody know how to end my goose chase? Link to comment Share on other sites More sharing options...
Zues Marine Posted June 29, 2015 Share Posted June 29, 2015 http://opposedforces.com/parts/legacy/us_b11/ Link to comment Share on other sites More sharing options...
Brackets Posted June 30, 2015 Share Posted June 30, 2015 Sounds like the drier to me. The switch on top is a pressure switch and if you're jumping it to get your compressor going you're low on freon. Link to comment Share on other sites More sharing options...
Bobbo63 Posted June 30, 2015 Author Share Posted June 30, 2015 so all i gotta do is recharge it? cause i thought the switch opened when the compressor built up enough pressure. Link to comment Share on other sites More sharing options...
Brackets Posted June 30, 2015 Share Posted June 30, 2015 Well you could just recharge it but there is a reason you don't have enough pressure in there. That switch is a safety to stop the compressor from running when there isn't enough freon in the system. You will have been leaking refrigerant from one or more of the orings and/or the compressor shaft seal or even the condenser. Link to comment Share on other sites More sharing options...
Bobbo63 Posted June 30, 2015 Author Share Posted June 30, 2015 so its like a low pressure cut out switch? then what shits the compressor off? or does it constantly run? Link to comment Share on other sites More sharing options...
