OhNineGT Posted June 27, 2015 Share Posted June 27, 2015 I need a reputable shop in Salt Lake City, Ut. I had my motor rebuilt (Top end- Warped heads, new valves, new gaskets.) and they guy didn't put my motor back together very well. I just found that my wastegate vacuum had a screw in it because he couldn't figure out where it was supposed to go. Took it to subaru and the guy said that he could see a lot of things that he didn't do right that need to be fixed. All that said, I don't need the motor pulled or anything, I just need everything to be looked over (Vacuum hoses, accessories, all hoses in general, etc). Does anyone know a shop that could get this done for me that knows what they are doing and are pretty quick at what they do? Link to comment Share on other sites More sharing options...
Max Capacity Posted June 28, 2015 Share Posted June 28, 2015 NASIOC may be a better place to ask. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
trr122 Posted June 28, 2015 Share Posted June 28, 2015 Solid Auto Works is pricey but good. I'm a fan of Paradise Automotive in Woods Cross, but they can be very busy. Link to comment Share on other sites More sharing options...
Draconian Posted July 1, 2015 Share Posted July 1, 2015 Do you mind sharing which mechanic/shop did the work for you? Link to comment Share on other sites More sharing options...
boxkita Posted July 3, 2015 Share Posted July 3, 2015 move to regional forum. Someone will be able to help you here... Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Hops Posted July 6, 2015 Share Posted July 6, 2015 As I mentioned in the other thread, Solid Autoworks. Did you try taking it back to the guy that did the work? Buy my cars! Link to comment Share on other sites More sharing options...
OhNineGT Posted July 7, 2015 Author Share Posted July 7, 2015 I ended up going to despain. They've been great. Highly recommend Link to comment Share on other sites More sharing options...
