Lawson Posted June 23, 2015 Share Posted June 23, 2015 Wednesday 17june2015 ringland failure, that weekend I start pulling parts and my buddy says he'll have his hoist here on sunday so I can get it on a stand. Sunday comes and I have engine ready to be pulled hoist can't be loaned out. *Mod list* Deutchwerks 740cc injectors Forge manual boost controller Invidia up pipe Cobb chatted downpipe Magnaflow catback K&N typhoons intake And more that ill update after work Sent from my pocket using Tapatalk Link to comment Share on other sites More sharing options...
Lawson Posted June 23, 2015 Author Share Posted June 23, 2015 Sent from my pocket using Tapatalk Link to comment Share on other sites More sharing options...
Lawson Posted June 23, 2015 Author Share Posted June 23, 2015 Saved Sent from my pocket using Tapatalk Link to comment Share on other sites More sharing options...
Lawson Posted June 23, 2015 Author Share Posted June 23, 2015 Going with Pacific engine for machine shop at this point im taking block and heads to them block will be bored and honed to fit wiesco 99.75 pistons heads will be inspected by them also new head studs gasket set just as a start list will continue to grow Sent from my pocket using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted June 23, 2015 Share Posted June 23, 2015 Those are ARP head studs, correct ? Did you finally get a hoist ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Lawson Posted June 23, 2015 Author Share Posted June 23, 2015 Those are ARP head studs, correct ? Did you finally get a hoist ? Yes apr head studs and no luck on hoist should be avail this coming weekend Sent from my pocket using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted June 23, 2015 Share Posted June 23, 2015 I gather your doing a fuel pump and bigger injectors too? Do you have a great Tuner picked out ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Lawson Posted June 23, 2015 Author Share Posted June 23, 2015 Have not decided on a tuner yet injectors are fairly new fuel pump is still to be determined Sent from my pocket using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted June 23, 2015 Share Posted June 23, 2015 I would start the car on the stock injectors or whats known to work and fuel pump. Just to rule out another variable when starting for the first time. Make sure you can remove your injectors easily in case you decide to upgrade them. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
boxkita Posted June 24, 2015 Share Posted June 24, 2015 I have a hoist. Well i ve been hoarding MrTris 's hoist. If i bring it down, his buddy can get it back too YYou need to pick a tuner or use cobb accesport. I have 740cc dw injectors. worked well for me. If you haven't had them cleaned or have the report on them, you should. The highest output goes on drivers side rear injector, #4 Whoever does your head work should do them based on fsm. Although every shop you talk to will use the aera book which says to trim the valves so be sure to specify which valves you want as replacement. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Max Capacity Posted June 24, 2015 Share Posted June 24, 2015 I have a hoist. Well i ve been hoarding MrTris 's hoist. If i bring it down, his buddy can get it back too YYou need to pick a tuner or use cobb accesport. I have 740cc dw injectors. worked well for me. If you haven't had them cleaned or have the report on them, you should. The highest output goes on drivers side rear injector (forget #) QUOTE] That would be #4 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Lawson Posted June 24, 2015 Author Share Posted June 24, 2015 I have a hoist. Well i ve been hoarding MrTris 's hoist. If i bring it down, his buddy can get it back too YYou need to pick a tuner or use cobb accesport. I have 740cc dw injectors. worked well for me. If you haven't had them cleaned or have the report on them, you should. The highest output goes on drivers side rear injector (forget #) QUOTE] That would be #4 Injectors were installed new 15k ago and were cleaned 6000ish ago when I thought they were the cause of an issue i have an access port but will also be deciding on a tuner soon as I get the engine to the machine shop. The hoist would be a huge help and greatly appreciated Sent from my pocket using Tapatalk Link to comment Share on other sites More sharing options...
Lawson Posted June 25, 2015 Author Share Posted June 25, 2015 Just found out today that im leaving the country for a week so everything is on hold Sent from my pocket using Tapatalk Link to comment Share on other sites More sharing options...
boxkita Posted June 26, 2015 Share Posted June 26, 2015 let me know on the hoist. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Lawson Posted July 7, 2015 Author Share Posted July 7, 2015 let me know on the hoist. Pm sent about hoist let me know so I can get it looked at and start ordering parts Sent from my pocket using Tapatalk Link to comment Share on other sites More sharing options...
Lawson Posted July 19, 2015 Author Share Posted July 19, 2015 Bought a hoist and stand got it all out, build is slow moving but happening. Sent from my pocket using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted July 20, 2015 Share Posted July 20, 2015 Make sure you clean all the grounds, may be make new ones for the chassis to the heads. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Lawson Posted July 20, 2015 Author Share Posted July 20, 2015 Make sure you clean all the grounds, may be make new ones for the chassis to the heads. Yeah for sure the car is from N.Y. and there is a lot of rust one of the grounds was just awful and broke off from removing the bolt Sent from my pocket using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted July 20, 2015 Share Posted July 20, 2015 Also, wire brush the matting surface of the block to tranny. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Lawson Posted July 22, 2015 Author Share Posted July 22, 2015 Getting sent out for another week stripping the engine when i get home then off to the machine shop Sent from my pocket using Tapatalk Link to comment Share on other sites More sharing options...
