urdrwho Posted June 17, 2015 Share Posted June 17, 2015 Everything was going well and it was the last idler to install. The threads are shot. Now what? Can I use a heli-coil or a good amount of JB weld into the hole and call it a day. The engine is pushing 330,000 and this may be its last timing belt. Link to comment Share on other sites More sharing options...
subieadam Posted June 17, 2015 Share Posted June 17, 2015 If that doesnt work I have a block for you. Link to comment Share on other sites More sharing options...
sbw Posted June 17, 2015 Share Posted June 17, 2015 helicoil it. You should be fine that way. Link to comment Share on other sites More sharing options...
johnegg Posted June 17, 2015 Share Posted June 17, 2015 easy fix. the tensioner bolts on to a bracket. go to a pick n pull and get a used bracket. 90 - 97 are the same, 98+ are the same. ej22 and ej25 are the same. Link to comment Share on other sites More sharing options...
urdrwho Posted June 17, 2015 Author Share Posted June 17, 2015 That is a bracket? I thought it was part of the block. easy fix. the tensioner bolts on to a bracket. go to a pick n pull and get a used bracket. 90 - 97 are the same, 98+ are the same. ej22 and ej25 are the same. Link to comment Share on other sites More sharing options...
johnegg Posted June 17, 2015 Share Posted June 17, 2015 bracket. Link to comment Share on other sites More sharing options...
Osei Posted June 17, 2015 Share Posted June 17, 2015 Just get the bracket style that matches your tensioner. O. Link to comment Share on other sites More sharing options...
bjkroll Posted June 21, 2015 Share Posted June 21, 2015 FYI, you can helicoil practically anything. But if its going into a block, just be sure you know where the debris from the new threads are going! (Such as, spark plug threads leading into a cylinder) Link to comment Share on other sites More sharing options...
elislider Posted July 1, 2015 Share Posted July 1, 2015 easy fix. the tensioner bolts on to a bracket. go to a pick n pull and get a used bracket. 90 - 97 are the same, 98+ are the same. ej22 and ej25 are the same. this is correct. only the tensioner is on a bracket. all the other timing idlers are on the block itself, and 1 is on the water pump Link to comment Share on other sites More sharing options...
