02603sec Posted June 13, 2015 Share Posted June 13, 2015 to pull the manifold, well its easy. there is going to be a challenge buttoning thia thing back up . Passenger side sensor. My research says to remove the fly baffles. but.. so I still need a new sensor? i have to replace the crapola turbo inlet as there was a tear from a previous turbo installa. The 200 k subie turbo is testing my patience. any insight is appreciated! Link to comment Share on other sites More sharing options...
02603sec Posted June 14, 2015 Author Share Posted June 14, 2015 The fuel line has 2 bolts upside down underneath the plenum, the harness pins are hard to get to especially the inside fuel injector and TGV sensor.. Fubared the one on the passenger side TGV sensor. This video is somewhat helpful My preference is just to fix or replace the sensor/or motor. How do I bench test them? If I pulled the butterflies or vanes, and left the rod, would I still get a CEL, if I didn't replace the motor or sensor? These directions are good, except, you want to unbolt the fuel lines first: http://www.scoobymods.com/showthread.php/mod-tgv-tumble-generator-valve-4371.html? This video is long. . but somewhat informative on gutting the Link to comment Share on other sites More sharing options...
02603sec Posted June 14, 2015 Author Share Posted June 14, 2015 Here is a good index on TGV delete, and or fix. Still doesn't tell me what the OHM test should be for the sensor. http://forums.nasioc.com/forums/showthread.php?t=1663677 Link to comment Share on other sites More sharing options...
Max Capacity Posted June 14, 2015 Share Posted June 14, 2015 http://people.csail.mit.edu/ilh/vacation/ the service manual should help. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
02603sec Posted June 15, 2015 Author Share Posted June 15, 2015 Oh my that is a much better file than my previous (vacation). Thank you sir:) I will read up Link to comment Share on other sites More sharing options...
02603sec Posted June 15, 2015 Author Share Posted June 15, 2015 dealer will only sell a full lower intake for $400+ and wants 300+ for a new turbo intake duct. I found a full package at a local junk yard for $200 off a 2005. The only diff looks like the injectors are square, while mine are yellow. Link to comment Share on other sites More sharing options...
KRM Posted June 15, 2015 Share Posted June 15, 2015 $300 turbo inlet? That is way too much if so....freaking dealerships man, never enough Link to comment Share on other sites More sharing options...
02603sec Posted June 16, 2015 Author Share Posted June 16, 2015 Yeah, I found the cross reference part for the Tumble Generator Valve Sensor is the Throttle Body Sensor. It's still 100+ bones. I figure with the Junkyard full intake assemble with all sensors, piping, harness, fuel lines and turbo duct as well. Is a good deal. Coincidentally hooked up with it locally on EBAY. can actually pick it up myself, and see if there are any other pieces I can pick off the carcass. Link to comment Share on other sites More sharing options...
02603sec Posted June 16, 2015 Author Share Posted June 16, 2015 Here's what I got for 200 bones.. the full monty.. I think I did good. http://legacygt.com/forums/picture.php?pictureid=10493&albumid=2011&dl=1434487478&thumb=1 http://legacygt.com/forums/picture.php?pictureid=10493&albumid=2011&dl=1434487478&thumb=1 Link to comment Share on other sites More sharing options...
02603sec Posted June 16, 2015 Author Share Posted June 16, 2015 http://legacygt.com/forums/picture.php?pictureid=10494&albumid=2011&dl=1434487478&thumb=1 Link to comment Share on other sites More sharing options...
02603sec Posted June 18, 2015 Author Share Posted June 18, 2015 yeah. Coolant temperature sensor was hidden under a vacuum device. Spent an hour looking for it. Everything went pretty smoothly with the wiring harness considering how many different ways to snap and unsnap those damned harness clips. The design to service the coil packs and plugs is laughable. Link to comment Share on other sites More sharing options...
02603sec Posted June 20, 2015 Author Share Posted June 20, 2015 everything back together. Did have a few glitches.. I overlooked a loose clamp on the FMIC plumbing feeding the MAF. Ran like hell, had thrown a p0302, but it smoothed out. Then I heard something like knocking.. oh my. But that went away too. A little squeaking from the alternator belt, which wasn't on all the way (dark garage). In the last 300 miles: new rear brake calipers, rotors pads, flushed brake fluid, 4 new Kumhos, replace the whole intake assembly, including the wiring harness. I had a P2016 which started all the work. My advice for anyone attempting this with the motor in the vehicle, take your time and all of the harness are a "Push and Release" type. I do have an extra harness, plenum, intakes and fuel lines. My test drive revealed this is the best this car has run since I bought it. Time for a beer. Link to comment Share on other sites More sharing options...
02603sec Posted June 20, 2015 Author Share Posted June 20, 2015 Next up is the Miata exhaust.. she hit a pothole and something broke. Link to comment Share on other sites More sharing options...
02603sec Posted June 20, 2015 Author Share Posted June 20, 2015 Thanks goes out to Max Capacity for the vacation file. Bred Feans by coincidence is the closest Subaru place to me. Link to comment Share on other sites More sharing options...
