Manchildlgt07 Posted June 8, 2015 Share Posted June 8, 2015 I found a v7 non dccd 6 speed and was wandering what I would need for the swap.. The final drive is the same so I can use my rear diff but would I need different axles? Is there any thing I should be aware about. Any input would be greatly appreciated thanx Link to comment Share on other sites More sharing options...
DeltaNu1142 Posted June 8, 2015 Share Posted June 8, 2015 Read this. Tits mcgee Link to comment Share on other sites More sharing options...
legacybt Posted June 8, 2015 Share Posted June 8, 2015 Just a heads up - your cruising RPM in 6th will be higher than it was for the 5-speed in 5th, so if you spend a lot of time on the highway I'd recommend USDM over JDM. If this is just a fun/track car, then go for it - the gear ratios are fantastic for the track. Link to comment Share on other sites More sharing options...
Manchildlgt07 Posted June 8, 2015 Author Share Posted June 8, 2015 Um I dont spend to much time on the highway but evey now n than Link to comment Share on other sites More sharing options...
Manchildlgt07 Posted June 8, 2015 Author Share Posted June 8, 2015 The tranny I found is from a jdm sti 01-02 Link to comment Share on other sites More sharing options...
