V7 non dccd 6 speed tranny in my legacy 07 help
I found a v7 non dccd 6 speed and was wandering what I would need for the swap.. The final drive is the same so I can use my rear diff but would I need different axles? Is there any thing I should be aware about. Any input would be greatly appreciated thanx
Just a heads up - your cruising RPM in 6th will be higher than it was for the 5-speed in 5th, so if you spend a lot of time on the highway I'd recommend USDM over JDM. If this is just a fun/track car, then go for it - the gear ratios are fantastic for the track.
