mass-hole Posted June 7, 2015 Share Posted June 7, 2015 I have a friend with an '08 outback which has very little power. It can drive, but barely gets out of its own way and takes about a half mile to get to 50mph. The engine runs and sound very smooth, no misfires or anything like that. Air filter is brand new it looked like, maf sensor seemed to be functioning based on my Torque pro app and everything seemed to jive. At first there was no codes but after a few restarts I got the A/T Oil Temp light flashing and a CEL. The codes were: P1718 - believe more specifically a trans temp sensor P0600 P0700 Anyone have any clue? Link to comment Share on other sites More sharing options...
apexi Posted June 7, 2015 Share Posted June 7, 2015 I did some brief research, and the first thing is I would check to see if the green test connectors are connected. It sounds like they should be in the same location for the outback, which is underneath the glove box, pictures in the link below. While it may be an unlikely fix, it's easy to check and easy to fix if that is the problem. http://legacygt.com/forums/showthread.php/green-connector-under-gloveboxi-76335.html From what I've read these are supposed to be unplugged unless you are doing something involving the ecu. Link to comment Share on other sites More sharing options...
DonnyJagaru Posted June 8, 2015 Share Posted June 8, 2015 Is it shifting gears alright? Link to comment Share on other sites More sharing options...
Wheelbuilder_25 Posted June 10, 2015 Share Posted June 10, 2015 It sounds like the ecu isn't communicating with the tranny based on the 1718 and 0700, but the 0600 means a general comm problem with one of the ecu controlled systems. I'd start by looking over the wiring, especially to the transmission. Link to comment Share on other sites More sharing options...
