mbciuso Posted June 6, 2015 Share Posted June 6, 2015 Hi I have 2007 legacy non turbo and am in need of new front brakes. I saw advance auto carries their wear ever brand and have silver, gold and platinum series. The biggest difference seems to be ceramic vs. semi metallic. Was wondering what is best. I know ceramic make less brake dust and have good stopping power, but I thought they were hard on rotors. What do you guys like to use? Thanks, Link to comment Share on other sites More sharing options...
Soarin Posted June 7, 2015 Share Posted June 7, 2015 I have EBC GD slotted and dimpled rotors paired up with Hawk HPS pads. It's a pretty good setup and I haven't had any issues. Granted these are more aggressive than the stock pads, but when I had the OEM rear rotors they held up perfectly fine with the HPS pads. Link to comment Share on other sites More sharing options...
GipsySpec.B Posted June 7, 2015 Share Posted June 7, 2015 I use semi-metallic Stoptechs with stock rotors and wash my wheels...often. The noise isn't that bad. As far as Ceramics on the stock rotors it's up to you. Depends on the driving style and where you live. Ceramics take a bit to warm up. Honestly as long as you bed the pads properly you'll have plenty of stopping power with the stock rotors and semi-metallic. Link to comment Share on other sites More sharing options...
gto7419 Posted June 8, 2015 Share Posted June 8, 2015 I use Porter field r4s in just about everything I own. They're cheap and at the bottom end of what I would consider a good autos pad. Excellent for the street. I only use cheapos rotors and have never had an issue - even with autox and rallyx. Pronto or centric are fine. Link to comment Share on other sites More sharing options...
parad1mg Posted June 8, 2015 Share Posted June 8, 2015 I'm not affiliated with Amazon.com but they always have the most affordable prices for pads and rotors. For pads: http://legacygt.com/reviews/showproduct.php?product=360&sort=2&cat=23&page=1 For rotors: Centric blanks/premiums. Please make sure you check for rotor run-out and make sure that the hub and mating surfaces are free of debris / dust upon installation. Also, follow the recommended bed in procedure for whatever brake pads you end up buying and properly torque all the bolts and lugs to spec. Here's a reference thread for your convenience: http://legacygt.com/forums/showthread.php/brake-pad-replacement-walkthroughi-133449.html Link to comment Share on other sites More sharing options...
Soarin Posted June 8, 2015 Share Posted June 8, 2015 ^^^^ This! Try to get parts of Amazon whenever you can cause the prices are usually the best and who's gonna argue with free shipping? Enter in the part number, double check it's what you need, and order. I got a set of rear EBC 3GD rotors for my LGT at $62 bucks when they're usually $180. I got the sale at the right time. Link to comment Share on other sites More sharing options...
apexi Posted June 8, 2015 Share Posted June 8, 2015 I would say that the wearever platinums are just ok. They're a ceramic pad, so you don't see a lot of brake dust on your wheels, and they're very quiet. What I don't like is that their performance is not very good in the winter time when they're cold. If you live somewhere that is warm all year I think they'd be fine, but they're not the greatest in the winter time when they're cold. Link to comment Share on other sites More sharing options...
paul7ro Posted June 18, 2015 Share Posted June 18, 2015 For daily driving needs, the Akebono is a good choice and not too expensive. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 18, 2015 Share Posted June 18, 2015 I just put Brake Performance slotted rotors and Premium Ceramic pads on my wagon last night, did the fronts two weeks ago. $321.00 for 4 rotors and both sets of pads. Free shipping. Had to grind a little metal off one of the inner rear pads, but that's nothing I haven't had to do before with Hawk pads. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Blue Posted June 18, 2015 Share Posted June 18, 2015 Hawk HPS pads and Centric rotors. I got them from JC Whitney. Link to comment Share on other sites More sharing options...
Mike07LGT Posted June 19, 2015 Share Posted June 19, 2015 Oem pads are usually solid and work perfectly fine for everyday driving. Thats what I bought and have zero issues with dust or noise 03 WRB WRX (RIP) 04 JBP STI (sold) 07 DGM Legacy GT (RIP) 12 OBP STI (DD) Link to comment Share on other sites More sharing options...
quick4dr Posted June 19, 2015 Share Posted June 19, 2015 my porterfield pads are awesome!! all for corners, with dba rotors from centric rear. stopping power is major upgrade from stock! Link to comment Share on other sites More sharing options...
Tronic Posted June 19, 2015 Share Posted June 19, 2015 Stock Subaru pads here, not cheap at NZ$120 a set for either fronts or rears but they are low dust and work well. I am running some sort of aftermarket slotted front and rear rotors however so I guess that helps. Always run stock pads these days, have tried custom made race pads in the past but its a waste of time for the road. Link to comment Share on other sites More sharing options...
boxkita Posted June 19, 2015 Share Posted June 19, 2015 hawk hps pads with centric premium blanks. If you run less than great tires and/or only run all-season tires, any other brake pad/disc upgrade is going to be wasted money. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
WahooNo2 Posted June 21, 2015 Share Posted June 21, 2015 hawk hps and racingbrake slotted rotors Link to comment Share on other sites More sharing options...
