silentsnow31802 Posted May 23, 2015 Share Posted May 23, 2015 Trying to pull a learning view from my 09 obxt. I have never done this with this specific car/laptop so I may be missing something. It will data log but there is no Cal ID in rom raider for my ecu. It says definition file does not exist when I try and pull the learning view. I remember having this issue when I got it tuned, on a different laptop though. I had to have a definition file made or found i cant remember which, that would allow ecu flash to connect to my ecu. I still have this file in my ecu flash directory but this is not what rom raider uses. Anyone here have a solution for me? I will continue to search in the mean time. Link to comment Share on other sites More sharing options...
silentsnow31802 Posted August 9, 2015 Author Share Posted August 9, 2015 Bump! Can get ecu flash to connect but still no romraider. Can't data log anymore. If I turn on canbus logging I can get it for a split second then it drops out. Sent from my C6916 using Tapatalk Link to comment Share on other sites More sharing options...
ktmrider Posted August 14, 2015 Share Posted August 14, 2015 Mine stopped working after a recent laptop change ( worked fine on same car with different laptop ). 64-bit systems on Windows = lots of legacy software issues in my experience. Haven't tried any Emulators yet ( XP or 32-bit ) Link to comment Share on other sites More sharing options...
silentsnow31802 Posted August 15, 2015 Author Share Posted August 15, 2015 Mine stopped working after a recent laptop change ( worked fine on same car with different laptop ). 64-bit systems on Windows = lots of legacy software issues in my experience. Haven't tried any Emulators yet ( XP or 32-bit ) Yes I have found this out. I purchased an Asus Eeebook a while back when it was on sale. Comes loaded with a slim install if windows 7 32bit. Huge battery life too. Perfect for a tuning laptop. Sent from my C6916 using Tapatalk Link to comment Share on other sites More sharing options...
heiche Posted August 15, 2015 Share Posted August 15, 2015 What ecu id do you have? BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 15, 2015 Share Posted August 15, 2015 OP, get heiche to help you with this, and then get the following tool. http://legacygt.com/forums/showthread.php/btssm-bluetooth-adapter-app-229709.html You will no longer need a laptop to log and pull lvs. Right in the palm of your hands. Link to comment Share on other sites More sharing options...
