Gex Posted May 21, 2015 Share Posted May 21, 2015 Wheel 6 is a Custom 18G Could you fit that wheel in a blown vf48 I have on my parts shelf? Been meaning to pm you and discuss a build for that sucker. Link to comment Share on other sites More sharing options...
JmP6889928 Posted May 21, 2015 Share Posted May 21, 2015 Could you fit that wheel in a blown vf48 I have on my parts shelf? Been meaning to pm you and discuss a build for that sucker. That wheel is only to fit on a Td05/06 shaft and has a 68mm back on it. It would not fit unless I did a hybrid thing like BNR does and then it would require extensive machining of the VF40 housing. Find a BNR 18G that's blown and send it to me and I can put that wheel in his setup and it will be SUBSTANTIALLY better than it was when new. I CAN do this to your VF48 with the #4 wheel though. Link to comment Share on other sites More sharing options...
Streetlegal Posted May 22, 2015 Share Posted May 22, 2015 That wheel is only to fit on a Td05/06 shaft and has a 68mm back on it. It would not fit unless I did a hybrid thing like BNR does and then it would require extensive machining of the VF40 housing. Find a BNR 18G that's blown and send it to me and I can put that wheel in his setup and it will be SUBSTANTIALLY better than it was when new. I CAN do this to your VF48 with the #4 wheel though. Damn that looks awesome. Got any combos that would be close to a GTX3076? Wanting to go rotated on E85 and make around 400/400 to the ground. Link to comment Share on other sites More sharing options...
