xyzb Posted May 15, 2015 Share Posted May 15, 2015 The car needs head gaskets but has 190k on it. I'm looking at a lower mileage engine/trans but they are from an Outback Legacy 2001-2005. Will they work in my car? The guy told me no problem but I just need to use my old intake on the newer engine. Both engines are 2.5 DOHC Any comments would be appreciated. Thanks! Link to comment Share on other sites More sharing options...
Max Capacity Posted May 15, 2015 Share Posted May 15, 2015 I thought 3rd Gen GT's were single cams. I had a 98GT 2nd Gen and a 00GT, 3rd Gen. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Hitokiri_Gensai Posted May 16, 2015 Share Posted May 16, 2015 All the us models were single cam engines but you could get turbo dohc engines in japan and other parts of the world. Link to comment Share on other sites More sharing options...
SBT Posted June 27, 2015 Share Posted June 27, 2015 1995-1999 2.5 Legacy is a DOHC. 2000+ 2.5 non-turbo is SOHC. And SUS is an Outback designation, not Legacy. And just an admin-keeping function. This forum is for members who are rebuilding their own engines. Moved to 2nd Gen Sub-forum where you'll likely get more info. Good luck with your project. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
