Jdemod Posted May 9, 2015 Share Posted May 9, 2015 Are Outback XT's known to have issues with cv boots? I had my passenger side front cv boot changed about a month ago since it was torn and I have a warranty. I went to change my oil this morning and saw that the drivers side is torn now as well. I was just curious as to when other people have run into this issue? My car only has 64k miles on it and this failure seems premature to me. Link to comment Share on other sites More sharing options...
WRX USA Posted May 9, 2015 Share Posted May 9, 2015 That seems odd given your relatively low miles. Are you the first owner? I also have an 09 OBXT and I live in Campbell with a couple hundred miles shy of 100K and I am on my originals. Link to comment Share on other sites More sharing options...
Jdemod Posted May 10, 2015 Author Share Posted May 10, 2015 Second owner. It was a lease car before (iirc) that I picked up with 54k miles in November. Link to comment Share on other sites More sharing options...
Nightmaresmk Posted May 11, 2015 Share Posted May 11, 2015 It's a common issue with the drive angel and age of the boots. It's normal to burn through the passenger inner boot after a couple years. Dry heat also doesn't help. I have swapped axles to reboot several times. not a huge issue. Link to comment Share on other sites More sharing options...
Heffernan Posted May 11, 2015 Share Posted May 11, 2015 I had both front boots replaced around 65-70k miles if I remember correctly. Link to comment Share on other sites More sharing options...
Jdemod Posted May 12, 2015 Author Share Posted May 12, 2015 I'll probably have the drivers side done some time this week. Link to comment Share on other sites More sharing options...
