mmarton Posted May 8, 2015 Share Posted May 8, 2015 Hi, Folks. I was replacing an LED in my dome light (2005 Legacy Wagon) and when I closed it up and tested, it fried the light fixture. So I did some searching and found a 2006 Outback dome light that fits perfectly. The only problem is the light will not turn on when I unlock or open the door. Any ideas? It works fine otherwise. Link to comment Share on other sites More sharing options...
DrD123 Posted May 9, 2015 Share Posted May 9, 2015 When you say it fried the fixture, do you mean it overheated/overcurrent and damaged the contact points? If it was on "door" when it did that, then you could have damaged the lead going to the body integrated unit since that's the one that controls the dome light when it's on the door setting. Maybe check the terminal at the BIU and see if it's damaged (or in the connector at the dome light) If nothing else is messed up, then the BIU itself is probably ok, which is good. Link to comment Share on other sites More sharing options...
mmarton Posted May 9, 2015 Author Share Posted May 9, 2015 Thanks. Good question. I don't remember what position the switch was in or if the door was open or closed. I'm dumb. What's a BIU? Link to comment Share on other sites More sharing options...
khaos_65 Posted May 9, 2015 Share Posted May 9, 2015 It stands for "body integrated unit" Have you checked your fuses? Just yesterday I was trying to swap some bulbs and I ended up killing the power to the interior lights and my key fob was not working. So took me a while to figure out what fuse it was and got it working again. Link to comment Share on other sites More sharing options...
mmarton Posted May 11, 2015 Author Share Posted May 11, 2015 Thanks. Yes, I've check the fuses several times. The lights work. The dome just doesn't work in the door position. Link to comment Share on other sites More sharing options...
rougeben83 Posted October 24, 2015 Share Posted October 24, 2015 Any update? Having the same problem. Link to comment Share on other sites More sharing options...
