yinlun Posted May 8, 2015 Share Posted May 8, 2015 On deceleration around 2700-3200 rpms, there will be a flapping sound. That's the best I can describe it. It almost sounds like a diesel rig during engine braking - but not as loud. The noise doesn't happen outside that range and only when I'm decelerating from load. I tried to recreate it without any load and I wasn't able to hear it. It's possible that the revs dropped too quickly as well. Most threads I'm finding on here refers to turbo engines and waste gates, so that hasn't really helped. The idiot light is off, so that's good I guess. But I haven't been able to pinpoint it, any ideas? Link to comment Share on other sites More sharing options...
orndog Posted May 8, 2015 Share Posted May 8, 2015 Car and mods please? Maybe it's just popping in the exhaust? Link to comment Share on other sites More sharing options...
yinlun Posted May 8, 2015 Author Share Posted May 8, 2015 It's an 05 2.5i - 5spd. There's no mods to the car. I can tell it's from the front of the car, and I believe driver side. But that may be because I can only hear it when I'm driving Link to comment Share on other sites More sharing options...
FJuan Posted May 8, 2015 Share Posted May 8, 2015 Check your exhaust heat shields, they tend to rattle/flap within that RPM range. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
DonnyJagaru Posted May 13, 2015 Share Posted May 13, 2015 Dirty air filter? Critter filled your air-box with straw, seeds, leaves etc? I have a rattling heat shield but it only does it when the engine is cold, and curiously when I'm accelerating. Link to comment Share on other sites More sharing options...
yinlun Posted May 15, 2015 Author Share Posted May 15, 2015 The good news, is it's fixed. The bad news, I'm not quite sure what it was since I did multiple things. 1. I installed a new AC belt using a stretch belt, my old pulley had shredded a while ago and I've been without AC. Instead of getting a new pulley, I replaced it with a stretch belt and eliminated the need for the pulley. I checked the alternator belt before I installed the stretch belt, and it seemed tight but I did snug it back up again. (Maybe the flapping was loose belts?) 2. I found the driver side front wheel well to be loose. It was only a couple of mm, but loose enough to allow play. I tightened that back up. It's possible it was this, but I doubt this could cause sound that would correlate to engine RPM & load instead of speed/airflow. Could've been because of how engine vibrations are transferred..but my bet is on #1 having fixed the issue and the Alternator belt wasn't as tight as I thought it was. Went for a drive and the flapping sound is gone. I did confirm the heat shields were loose and there is a rattling. I still haven't fixed those, but this was a different sound - non metallic. I'll have to address the heat shields next.. Thanks for the help! Link to comment Share on other sites More sharing options...
