alyolles Posted May 5, 2015 Posted May 5, 2015 So I need a new fuel pump for my 05 lgt with vf52 turbo. I will be getting bigger injectors in the future and since I have to upgrade now because my current one is dying, I'd like to not have to replace it a second time. What pump should I buy and what will be the easiest to install?
alyolles Posted May 5, 2015 Author Posted May 5, 2015 Thinking this http://www.rallysportdirect.com/DeatschWerks-9-652-1008-65c-Series-Fuel-Pump-w-Install-Kit#tab-3
mwiener2 Posted May 5, 2015 Posted May 5, 2015 Go overkill or go home. http://legacygt.com/forums/showthread.php/400-and-720-lph-intake-fuel-modules-239696.html My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons
alyolles Posted May 5, 2015 Author Posted May 5, 2015 That costs a bit more than the $150 for the deatschwerks haha
alyolles Posted May 5, 2015 Author Posted May 5, 2015 Is there anyway to see the fuel pressure on the AP V2 to see if my car is running lean due to my pump not holding pressure like my tuner says?
travrach Posted May 7, 2015 Posted May 7, 2015 41 - 46 psi regulator disconnected 33 - 38 psi regulator connected
mwiener2 Posted May 7, 2015 Posted May 7, 2015 You need to hook up a fuel pressure gauge in the engine bay to see what the pressure is. The car does not have a fuel pressure sensor from the factory. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons
alyolles Posted May 8, 2015 Author Posted May 8, 2015 Well thats stupid... Im guessing its pretty shot being its ten years old, and basically asking it to work at 120 percent with my vf52 and thats why im running lean.
Legit_LGT Posted May 8, 2015 Posted May 8, 2015 The DW65C is really well built, and gives quite a bit of headroom for the fuel system. The type of pump depends on how big of injectors you are going with in the future. When I replaced my pump with a DW65C I also replaced the filter. It made the installation a bit easier I believe. When you go to replace the fuel pump, just make sure you gas tank is no more than 1/4 full, or else it gets pretty messy. Here's a link to the filter
alyolles Posted May 8, 2015 Author Posted May 8, 2015 Thanks for the advice, planning on going with 1000cc injectors in the future which i've heard this pump will handle just fine. Eh would rather not spend the money on a new filter now. I'll do it when I need another new pump for bigger injectors and tracking the car.
Max Capacity Posted May 8, 2015 Posted May 8, 2015 PM "underdog" and see what he can do for pricing. Or Mike at www.AZPinstalls.com 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here
Max Capacity Posted May 8, 2015 Posted May 8, 2015 Anything you need. They can get you anything, that's what they do. I just tell them what I want or ask them to send me what they would use. It's that easy. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here
