SubyFirstTimer Posted May 5, 2015 Share Posted May 5, 2015 I am a new (3 months), first time LGT owner and still relatively new to Pittsburgh (4 years). Are there any good mechanics in the area, specifically on the East side? Link to comment Share on other sites More sharing options...
Eliott Posted May 5, 2015 Share Posted May 5, 2015 Moore performance in Mckees Rocks. I'm a regular there and they've been great. Turbo subarus are their specialty, bunch of great guys. Talk to Ryan Moore, the owner, and say Eliott sent you. Link to comment Share on other sites More sharing options...
BoozeRS05 Posted May 5, 2015 Share Posted May 5, 2015 East side of Pittsburgh - you could try PRL motorsports in Export or TPG in Blairsville. What kind of work are you having done? EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
SubyFirstTimer Posted May 6, 2015 Author Share Posted May 6, 2015 Thanks for the info. I have a post on the ECU Trouble codes list 05-06-07 LGT thread in the 4th Generation Legacy Forum area, if you really want to know what is going on. Sorry I don't have time to tell you what is going on with my car right now. Link to comment Share on other sites More sharing options...
BoozeRS05 Posted May 6, 2015 Share Posted May 6, 2015 I was driving my '06 LGT home from work on Friday and the check engine light came on. Being a first time owner of a Subaru, I was unaware that the thermostat pegs as part of the check engine warning so, I immediately assumed it had overheated. After I got it into a parking lot and let it set a couple minutes, I turned on the ignition and the temperature gage was showing normal but the cruise light was still flashing. Not sure what might the issue might be, I had the car towed to the dealership that I bought the car from about 2 months ago. They didn't get to it until Monday afternoon and mysteriously the check engine light was not on anymore and the computer was not registering that one had ever been on. I know I didn't dream it, since this is the first time I have ever witnessed a Subaru check engine light scenario. Does anyone have any ideas how a car sitting for 2-1/2 days would automatically clear a check engine light and wipe any sign of it from the CPU's memory? FYI-It had been more than a week since I put gas in it for anyone who thinks I didn't tighten the gas cap. Also about a month or so ago, the dealer replaced the dual climate control unit. Other evidence did not indicate that the car overheated. I turned the ignition on a couple minutes after I shut off the car and the temp gage was reading just shy of midway which is unlikely if I had just overheated it. The overflow tank was at a normal level and showing no signs of having had hot coolant dumped into it. After it had cooled down enough to open the radiator cap the fluid level was right up to the cap. In spite of this, the dealer said the car no longer had a check engine light when they looked at it and the computer didn't have a log of a check engine event. They spent a day trying to duplicate it and could not so, I have my car back and am unsure of when it might show up again. It happened again, but this time I knew how to access the engine code and it came up P0600 Serial Communication Link. Even though I took it back to the dealer with the check engine light on and they checked the code themselves, they say the code is too vague to ID without it occurring while they are monitoring it in real time. What appears to be common in both cases is that it was a warmer day (70's) and the engine was effectively idling (the first time I was coasting downhill and this time I had just started the car in the parking lot at about noon). Needless to say this is getting frustrating since the dealer's mechanic can't seem to duplicate the problem. So they will probably send me home again under the assumption that it will reappear and then I will bring it back to them again for the same runaround. Is there anyone in the Pittsburgh area that can recommend a really good mechanic? Most dealership mechanics don't seem to be very good. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
