kcmusa Posted May 1, 2015 Share Posted May 1, 2015 My turbo has play and is in need of replacement. what are some good shops in the northern va area? Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted May 1, 2015 Moderators Share Posted May 1, 2015 In order of distance (depending on exact location): Moore Performance, PTuning, MachV, AndrewTech, IAG. Given my druthers I would probably go to Andrewtech or IAG over the others, but I'm sure that all could successfully replace your turbo. If you are looking for a "shadetree" or private mechanic to swap things, shoot me a PM. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
acumenhokie Posted May 2, 2015 Share Posted May 2, 2015 In order of distance (depending on exact location): Moore Performance, PTuning, MachV, AndrewTech, IAG. All good recommendations. Link to comment Share on other sites More sharing options...
kcmusa Posted May 4, 2015 Author Share Posted May 4, 2015 Thanks Andrewtech not to far, will look them up. Link to comment Share on other sites More sharing options...
700watts Posted May 4, 2015 Share Posted May 4, 2015 In order of distance (depending on exact location): Moore Performance, PTuning, MachV, AndrewTech, IAG. Given my druthers I would probably go to Andrewtech or IAG over the others, but I'm sure that all could successfully replace your turbo. If you are looking for a "shadetree" or private mechanic to swap things, shoot me a PM. Take MachV of the list and add Atlantic motor sports. Link to comment Share on other sites More sharing options...
rlax31 Posted May 4, 2015 Share Posted May 4, 2015 I just had my turbo replaced after it failed at PTuning a few weeks ago so they have recent experience doing this work. I went with a VF52, high flow down pipe, catless uppipe, new oil lines, Cobb AccessPort, and full dyno tune. They also have replaced my timing belt, axles, and an oil leak I had at the oil cooler. So far it seems like the work they did was done very well. The car is running strong. Their customer service is good, but not great. They are pretty busy so it may take up to a week to get your car started. Link to comment Share on other sites More sharing options...
