maf help
Posted
So my car started to shutter when I come to a stop and my cel says maf so I replaced it w a new oem one car still shutters at stop I updated my map and still nothing anyone have any ideas?
Posted
Put the stock air intake back on. You don't need that other CAI.
The stock one is good till about 400whp.
Engine Build - Click Here
Posted
Maybe Tris can chime in here for more detail on this as he recently posted that the after market intakes can cause pre-detonation (read ring-land failure) because the MAF cannot properly read the volume of air being taken in by the intake. As was said above, put the stock intake back on as the AM intake provides no benefit unless you're pushing really high ponies.
Posted
P0147 I think it said maf failure
It's gone now but my AP says it could be the 02, manifold gasket , or tmic gasket
I check all visible hoses for leak found none so I ordered everything the AP Said It Could Be
I have no stock parts to put back on all mods came on car when purchased last year I've replaced many parts since purchase all I want is for it to be done and reliable when it's running great it's an animal I'm just pampering it now till I get this issue solved even bought a beater to drive for now
Posted
More then likely the sensor heater is bad, and you need a new one. But you should check the voltage at the sensor to make sure it has power to run the heater. Google test 02 sensor heater.
