whitrzac Posted May 25, 2015 Share Posted May 25, 2015 It sounds like it's not calibrated properly/at all. My LC2 is doing something similar after disconnecting the sensor to remove the downpipe. The LC2 automatically resets the calibration if it's turned on without the sensor plugged in. Link to comment Share on other sites More sharing options...
Markbo Posted May 26, 2015 Author Share Posted May 26, 2015 Im glad you mentioned it. I did recalibrate the other O2 sensor several times thinking the same thing and ciontinued to get too low readings. That was what lead to the recommendations to replace the O2. Before installing the new one I tried the calibration but the blinking did not go as its supposed to. Even with O2 not attached the light stayed on and did not blink at all like its supposed to. I followed all the directions and it didnt work right. Did a Romraider test anyway and got the same low numbers I was getting previously. Link to comment Share on other sites More sharing options...
