Nightmaresmk Posted June 2, 2015 Share Posted June 2, 2015 http://imageshack.com/a/img905/3660/Ov8jQG.jpghttp://imageshack.com/a/img633/2469/tREXTD.jpgStraight from IAG for future reference. http://imageshack.com/a/img540/8302/n4iDc9.jpg This is where the last vent connects too. http://imageshack.com/a/img910/9805/RwtwQA.png The Coolant lines run the top prefabbed line to the turbo expansion tank the bottom line runs to the turbo coolant line. Link to comment Share on other sites More sharing options...
sjxbrd Posted June 2, 2015 Share Posted June 2, 2015 Nightmaresmk thanks for those photos! Here are a couple photos of mine installed. The big AOS and my big TMIC did not fit, I had to make a little extension plate for the AOS (see the silver piece in first photo). Link to comment Share on other sites More sharing options...
IAG Performance Posted June 2, 2015 Share Posted June 2, 2015 http://imageshack.com/a/img905/3660/Ov8jQG.jpghttp://imageshack.com/a/img633/2469/tREXTD.jpgStraight from IAG for future reference. http://imageshack.com/a/img540/8302/n4iDc9.jpg This is where the last vent connects too. http://imageshack.com/a/img910/9805/RwtwQA.png The Coolant lines run the top prefabbed line to the turbo expansion tank the bottom line runs to the turbo coolant line. Thanks for assisting the community with the instructions and offering valuable feedback. We have actually addressed the coolant fitting access as well now have a drain fitting that is designed for AN (used on our Race AOS to be offered soon). We appreciate the feedback and are working on a few bracket options to improve install. The challenge we don't speak about often is trying to maintain 1 bracket to cover 2002-2015 cars so that our wholesalers can minimize how many part numbers they need to stock. This means it's a balancing act if you know what I mean. Nightmaresmk thanks for those photos! Here are a couple photos of mine installed. The big AOS and my big TMIC did not fit, I had to make a little extension plate for the AOS (see the silver piece in first photo). sjxbrd, If you shoot me an email to JJ "at" iagperformance.com I am happy to send you a bracket that we offer for rotated turbo kits. This pushes the AOS farther back much like your extension bracket. This should solve your issue and be 1 piece powder coated aluminium. Regards, JJ Thank you everyone for the kind words. We welcome and appreciate the suggestions. We are constantly improving our design. Link to comment Share on other sites More sharing options...
Nightmaresmk Posted June 3, 2015 Share Posted June 3, 2015 IAG is their a bracket for us with the pitch mount that pushes it away from the ac line? Thanks again. Link to comment Share on other sites More sharing options...
Nightmaresmk Posted June 3, 2015 Share Posted June 3, 2015 I like IAG products everything has been well built, wish i could have gotten their billet tgv deletes. http://imageshack.com/a/img633/8011/9r1dWu.jpg Link to comment Share on other sites More sharing options...
quick4dr Posted June 3, 2015 Share Posted June 3, 2015 if my measurements are correct, the bracket needs to extend 1in longer to clear the ac line Link to comment Share on other sites More sharing options...
Nightmaresmk Posted June 8, 2015 Share Posted June 8, 2015 Hopefully IAG comes back with updates. I ran into an issue with the coolant lines needing 90degree bends to get around the stock lgt turbo setup with out kinking the lines. Link to comment Share on other sites More sharing options...
quick4dr Posted June 9, 2015 Share Posted June 9, 2015 product is great however perfect fitment for the legacy platform was rushed. a pitch stop mount bracket revision is needed for more clearance around AC line. im almost thinking of custom mounting it where my intake box was off of the fender wall. lots of space there and plenty of room to route lines. Link to comment Share on other sites More sharing options...
Nightmaresmk Posted June 9, 2015 Share Posted June 9, 2015 I wanted the center mount because that's the best spot to avoid oil in it during the corners. Which adds another layer to the protection. Link to comment Share on other sites More sharing options...
Nightmaresmk Posted June 10, 2015 Share Posted June 10, 2015 Finally installed. the lines every where but the fact my inlet won't be coated in Gunk makes me feel a lot better. http://imageshack.com/a/img901/4900/z8Kdoq.jpg Link to comment Share on other sites More sharing options...
Th3Franz Posted June 10, 2015 Author Share Posted June 10, 2015 Looks good. I ordered the pitch mount bracket since I'm going rotated now. Just arrived with their AVCS oil feed line kit. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
Nightmaresmk Posted June 10, 2015 Share Posted June 10, 2015 As stated their is an issue with the AC line. If they had a 1inch offset block it would fit perfect. It does work where it is just sits on the ac line. Link to comment Share on other sites More sharing options...
quick4dr Posted June 15, 2015 Share Posted June 15, 2015 As stated their is an issue with the AC line. If they had a 1inch offset block it would fit perfect. It does work where it is just sits on the ac line. Correct a 1 in spacer to bolt in between would set it perfect! Link to comment Share on other sites More sharing options...
NSFW Posted February 25, 2016 Share Posted February 25, 2016 1 inch offset in which direction? Toward the front of the car? Would it need to be a full inch or would a half-inch suffice? I'm going to get a new AOS, and this seems to be the leading contender. Link to comment Share on other sites More sharing options...
boxkita Posted February 25, 2016 Share Posted February 25, 2016 Are you going to print it? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
quick4dr Posted February 25, 2016 Share Posted February 25, 2016 1 in toward motor. away from firewall. Link to comment Share on other sites More sharing options...
quick4dr Posted February 25, 2016 Share Posted February 25, 2016 1 inch offset in which direction? Toward the front of the car? Would it need to be a full inch or would a half-inch suffice? I'm going to get a new AOS, and this seems to be the leading contender. you will love it, performance is awesome. fitment as you know can be improved if using the pitch bracket. I cant comment as for fender-wall installation. Link to comment Share on other sites More sharing options...
NSFW Posted February 26, 2016 Share Posted February 26, 2016 I did give it some thought. I don't think I'd trust ABS to hold something this large but I might change my mind after I actually get one in my hands. From looking at the pictures of the bracket on IAG's web site, I suspect you could improvise a spacer pretty easily with a chunk of metal, a drill press, and some longer bolts. Link to comment Share on other sites More sharing options...
Th3Franz Posted February 26, 2016 Author Share Posted February 26, 2016 I have the pitch bracket that I haven't used. Willing to sell if anyone wants it -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
Nightmaresmk Posted February 26, 2016 Share Posted February 26, 2016 Make adapter brackets to move it forward and hook us up. Link to comment Share on other sites More sharing options...
boxkita Posted February 26, 2016 Share Posted February 26, 2016 I did give it some thought. I don't think I'd trust ABS to hold something this large but I might change my mind after I actually get one in my hands. From looking at the pictures of the bracket on IAG's web site, I suspect you could improvise a spacer pretty easily with a chunk of metal, a drill press, and some longer bolts. If you do this, I'd buy a part. I need to replace my gs aos and the iag sitting in the cart. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Nuclear Posted March 6, 2016 Share Posted March 6, 2016 I have GrimmSpeed TMIC - will this IAG AOS mount my system OK without any problems? Link to comment Share on other sites More sharing options...
boxkita Posted March 8, 2016 Share Posted March 8, 2016 I have GrimmSpeed TMIC - will this IAG AOS mount my system OK without any problems? I'd ask iag. Then again how good are your fab skills? Curious why you think you need this? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Nuclear Posted March 8, 2016 Share Posted March 8, 2016 I'd ask iag. Then again how good are your fab skills? Curious why you think you need this? I emailed IAG About "Why" - alittle bit oIL "eating" Link to comment Share on other sites More sharing options...
