Impulse Posted April 2, 2015 Share Posted April 2, 2015 After about 4.5 years and 45k miles, the pressure plate on my ACT SB5-HDSS finally gave way - although there were signs for about two years Symptoms About two years ago I noticed that my clutch got harder and harder to engage. It was very gradual so I didn't really notice the increasing pedal effort until my left foot started to hurt after long city drives. I did notice, however, that when it was cold, my clutch would not disengage until everything warmed up. No matter how I adjusted the clutch, for the past year or so there didn't seem to be enough "throw" in the slave cylinder to disengage the clutch. I even replaced the slave and master cylinders, and bled the clutch system every month - but it would be very hard to get into gear. The engagement point was always half an inch off the floor (how I like it) . Failure It finally gave way this spring when things warmed up and I STILL could not disengage the clutch. About a month ago I heard a loud "pop" and a rattling sound pulling out of my driveway. I thought I had ran over something at first, but the sound went away halfway down the street - so I ignored it after doing a check of the car. Clutch replacement About two weeks ago it was so bad I could not get into first or reverse gear - it was time to replace the clutch. Initially thinking it was a failed TOB that was dragging, I took off that rubber dust boot to take a look into the bell housing area and noticed that the pressure plate fingers were not very even. Well.. it turns out that popping and banging sound a month ago was a pressure plate finger snapping, bouncing around the bell housing and spalling out a chunk of Al from the outside, before finally exiting out the bottom somewhere. What a mess. Two of the teeth broke off with only very little pressure when I reached down to pull the assembly out. Make that my second clutch replacement due to failed attached hardware. My first clutch was replaced at ~63k because the stock DMFW broke and rattled like crazy on deceleration. Now my second clutch has died due to a broken pressure plate - even though I still have clutch material left! We'll see if the new SPEC Stage 2+ hardware is any better TOB still good-ish! Video: https://youtu.be/foBHHwwzJ1o http://s18.postimg.org/i7fmooc8l/IMG_20150329_194931.jpg http://s18.postimg.org/rdxxbyhh1/IMG_20150329_194959.jpg http://s18.postimg.org/fz1g7c54l/IMG_20150329_195029.jpg http://s18.postimg.org/dt2jz3cad/IMG_20150329_195051.jpg http://s18.postimg.org/jjxbqk9o5/IMG_20150329_195315.jpg http://s18.postimg.org/dqn9pzy0l/IMG_20150329_181730817.jpg http://s18.postimg.org/au08pps6t/IMG_20150329_181807053.jpg http://s18.postimg.org/4y6b2bcvp/IMG_20150329_181835421.jpg http://s18.postimg.org/whp705sl1/IMG_20150329_181846128.jpg Link to comment Share on other sites More sharing options...
Max Capacity Posted April 6, 2015 Share Posted April 6, 2015 I have another Spec 2+ in my wagon. This one works easier then the old 2+. The Spec 2+ will make a howl sound when you let the clutch out in 1st great sometimes. That's normal. It's caused by the friction material. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Impulse Posted April 8, 2015 Author Share Posted April 8, 2015 Thanks Max, your reviews were critical in my decision to choose the Spec 2+ clutch since the Exedy I was looking at originally totally went out of stock everywhere. I never liked the idea that the Spec 2 could not handle an accidental high heat cycle, and liked the Spec 2+ because it had more capability to do that. I'm ~150 miles into the break-in, and I've found the "engagement zone" to be quite small (leading to jerky starts for now) and it to be a little bit chattery if I slip the clutch too slowly. Is this something that might get better as I approach the 500 mi break-in mark? I'm glad to hear that this clutch works better than a previous design. Was there any major physical change you noticed when putting the new one in? I have another Spec 2+ in my wagon. This one works easier then the old 2+. The Spec 2+ will make a howl sound when you let the clutch out in 1st great sometimes. That's normal. It's caused by the friction material. Link to comment Share on other sites More sharing options...
