justinmnhall Posted March 18, 2015 Share Posted March 18, 2015 Hello, having trouble identifying what the issue is. At a crawl speed nothing. Apply breaks ar regular speed and come to a full stop a clunk or twang sound from front somewhere. Just replaced hub rotors and pads. Any ideas? Ball joint or maybe sway bushings? It breaks just fine when driving just when I fully stop.please help lol Link to comment Share on other sites More sharing options...
ras06LGT Posted March 19, 2015 Share Posted March 19, 2015 Check sway bar end links, sway bar mounting bushings, and springs (upper/lower perches, physical spring damage, etc.). Link to comment Share on other sites More sharing options...
justinmnhall Posted March 19, 2015 Author Share Posted March 19, 2015 The link from control arm to sway the bushings are shot it looks like. I'll replace those see if that helps. Thanks! Link to comment Share on other sites More sharing options...
DeltaNu1142 Posted March 19, 2015 Share Posted March 19, 2015 Check caliper bolts for tightness. Tits mcgee Link to comment Share on other sites More sharing options...
justinmnhall Posted March 19, 2015 Author Share Posted March 19, 2015 Ok just replaced bushings and no change. And calipers is torqued to spec. Link to comment Share on other sites More sharing options...
justinmnhall Posted March 19, 2015 Author Share Posted March 19, 2015 Turns out something to do with abs system. No abs light on but brakes grab. Pull abs fuses light on but brakes fine. So must be the sencors got dirty Link to comment Share on other sites More sharing options...
DeltaNu1142 Posted March 19, 2015 Share Posted March 19, 2015 Where is the sensor now? It may have gotten moved during the hub removal & not reinstalled quite right. Tits mcgee Link to comment Share on other sites More sharing options...
justinmnhall Posted March 19, 2015 Author Share Posted March 19, 2015 Sensor still in correct place just really dirty, maybe needs replaced I'll have to check that out. On the pass side front the wheel was shot. Hub rotor lots of metal shrapnel , might have fouled things up a bit Link to comment Share on other sites More sharing options...
justinmnhall Posted March 19, 2015 Author Share Posted March 19, 2015 Unfortunately I'll have to wait as my jetta was broken into and all tools stolen except what few I have in the house > have to save up to replace them. Deductible on the insurance is $1000 and mine totaled about$500 so mad about it! Link to comment Share on other sites More sharing options...
